Did something dumb - help please
Old Sep 4, 2009 | 10:40 AM
JerryGarcia4295's Avatar
JerryGarcia4295
Default Update
Ok ... I borrowed a voltage meter. I pulled the new battery and charged it up - tested to make sure it had approx. 12.5 sitting on the porch. Installed said battery and started the bike ... voltage meter showed approx 12.3. Ok, so now I know for sure it isn't charging. Does that mean it is the stator? Could it still be the voltage regulator? My shop manual is still at home and I'm not
How do I test the various pieces w/o taking the primary apart? The VR is on the front of the bike right? This guy is going to start carrying that damn manual around in the saddle bags. Thanks in advance for any and all advice.
Old Sep 5, 2009 | 08:46 AM
jimsflh's Avatar
jimsflh
You don't, just order the stator, then take the primary apart to install it. I put a 3 phaze 40 amp system in (Be sure to use the screws they send, not your old ones, the new are longer for a reason, trust me on this, save buying yet another one)
Old Sep 5, 2009 | 10:05 AM
JerryGarcia4295
Ok ... I'm gonna limp it home and tear into it tomorrow or Monday ... is this strictly a stealer part or can you get them after market someplace?
Old Sep 6, 2009 | 11:23 AM
jimsflh's Avatar
jimsflh
I got mine through custom chrome, or vtwin. but here it is:
http://www.compufire.com/harley-main.html
You may be able to get it locally.
Old Sep 6, 2009 | 12:26 PM
Mole Rat's Avatar
Mole Rat
Originally Posted by 07bobber
Take it to the dealer if you have a warranty....
I agree
Old Sep 8, 2009 | 08:30 PM
JerryGarcia4295
Originally Posted by Mole Rat
I agree
No warranty ... already tore it apart ... worse than I thought ... pics to follow. I have pieces of copper wire in the primary and bolt heads stuck to the magnets in the rotor ... ****!
Old Sep 8, 2009 | 08:43 PM
kk6pg's Avatar
kk6pg
Look on the bright side, if you can call it that.
You didnt fry it by jumping the bike
Old Sep 8, 2009 | 08:53 PM
JerryGarcia4295
Uhhh I'm pretty sure I did ... I think I fried it bad then it "stuck" in the rotor and tore the hell out of everying in that area ... the up side is everything else looks ok
Old Sep 8, 2009 | 11:26 PM
harper764's Avatar
harper764
try giving the battery a full 24 hour charge....its not going to take enough juice from the bike to keep a charge
Old Sep 8, 2009 | 11:34 PM
NoLongerAmember's Avatar
NoLongerAmember
Na, the stator probably just came apart like a lot of other 06's. Aren't some dealers fixing this out of warranty? Or is that the IPB? Might look into it.
CB
