Did something dumb - help please
My understanding is that the current is a factor of resistance versus voltage. So the only way that I can see a running car damaging a bike is if the charge voltage of the car is a lot higher than the charge volatage of the bike.
Is that the case?
You cant push more amps than is required so an amp rating of an alternator is the maximum amount that can be pulled by the device that is being connected and not the number of amps pushed out.
Given that the charge voltages are the same, say nominal 14V, then the resistance of the bike battery is going to be static and thus the current will be the same regardless of whether it is the car alternator or bike stator doing the charging.
That is one of the reasons the voltage regulator is there is to keep the voltage steady.
Cheers
David
Unfortunately, life looks at it differently. The regulator is designed to operate with voltage and amperage going one way. When you jump it from a running vehicle, you put reverse bias against it. The regulator dont like that. As long as theres no forward bias, the regulator doesnt care about the reverse. The minute the bike starts and there is forward bias, something has to give. Add to it the magnetic field that collapses around the jumper connection when you disconnect (spiking into the thousands of volts reverse bias), the regulator is going to try its hardest to stop it. If it cant, it goes POOF. If it dont go Poof fast enough, I'll bet you cant guess whats next in line.....
Otherwise, use a piece of 14 gauge wire between the jumper cables and the bikes battery, and you have a 99% chance of not doing any damage
If you have a good connection you should not need to have the jumper vehicle running in order to start your bike anyway. You should connect the positive to the BAT and negative to the engine ground, not @ the Batery. On newer vehicles it is very unsafe to jump them either, I have seen many a fried ECM!
