vibrations???
Old Jun 13, 2006 | 04:13 PM
Keith_H's Avatar
Keith_H
Default RE: vibrations???
I thought mine was vibrating more than it used to, really alot more but i wasn't sure if it was me or my numb hands and mirrors that where unusable.
I read on here awhile back that motor mounts might cause this so i went in and told them to check my motor mounts. Sure enough, mine needed adjustment (4500 miles). I'm not sure whether i was happier about the fact that it vibrates a whole lot less or i acted like i knew what i was talking about.
Old Jun 13, 2006 | 05:09 PM
Z's Avatar
Z
Man, I would hope that a bike with only 100 miles would not need to be aligned, but you never know. Things slip through QC no matter how good you are.
Old Jun 13, 2006 | 09:33 PM
WildBill76's Avatar
WildBill76
My Bike vibrates a little at Idle. If my bike had no vibration, I would not be happy. Its vibration is like a heartbeat to me.
Old Jun 13, 2006 | 09:46 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My bike vibrates.......at idle mostly but not much since the break in and dyno tune. It vibrates on deceleration but that's all.
Old Jun 14, 2006 | 11:30 AM
QT Hush's Avatar
QT Hush
My Electra Glide vibrates crazily. What is the procedure for re-alignment, anyone know?
Old Jun 14, 2006 | 12:40 PM
fl_799's Avatar
fl_799
Anybody who thinks a Dyna vibrates excessively should live on a solid mount motor for a few weeks and 'man up'. It will reset your tolerance for vibration in short order. For me, my '06 is Dyna is like a revalation in smoothness but at the same time, I'd have no bones about buying another solid mount pan, shovel or EVO....in a heartbeat.
Old Jun 14, 2006 | 01:34 PM
Z's Avatar
Z
The procedure is to buy a Harley service manual. If it's anything like aligning a Wide Glide, you're best off reading the detailed descriptoin right from the source. Besides, the money you'll save by putting that manual to use in your garage will save you phat dollars in the long run, and get you on the road fast when something goes wrong minutes before a planned ride.
Old Jun 14, 2006 | 01:46 PM
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: NEONNIGHT34609
2006 street bob .. vibrates at idle..way cool but other then that she feels great
Mine only shakes at idle, and I like it. As far as I'm concerned, thats how a Harley should be.
Old Jun 14, 2006 | 02:32 PM
TOMMAY's Avatar
TOMMAY
Mine vibrates at idle and you can feel a little vibration in the pegs at low rpms expecially when the bike is cold.Not enough to be bothersome to me.
As far as vibration at speed,smooth as silk.I've ridden for hours at 80mph and have been up to 105,smooth and rock steady.
Good Luck
Tom
Old Jun 14, 2006 | 03:22 PM
razzoo76's Avatar
razzoo76
I have had my FXDI for about a month and have not noticed any vibrations
