Dodged a bullet...
Old Sep 9, 2009 | 09:11 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Default Dodged a bullet...
My bike came from the dealer with a charger pigtail wired in. It had always been tucked behind the front of the upper belt guard. I pulled it out a while ago while cleaning and found this...
The plastic had been worn thru within a couple thousandths of shorting out the positive leg to the belt guard it had been vibrating against for 16K miles!
Whew!
Old Sep 9, 2009 | 09:17 PM
Ratbob's Avatar
Ratbob
Good catch Patrick! That could have gotten real interesting, glad you caught it when you did.
Old Sep 9, 2009 | 09:25 PM
Topspin's Avatar
Topspin
You'd need a new bike before it got to be a problem. The white part is the hard stuff!
Old Sep 9, 2009 | 10:50 PM
danktat's Avatar
danktat
I keep mine under the seat between the battery and the fuse box covers.
Old Sep 9, 2009 | 10:58 PM
ackman1968's Avatar
ackman1968
You probably would have been OK had not crossed the mountains last month. Even as little as a day on the dry east side exposes you to more gritty abrasive contaminants than you would see in a ten year time span on the west side.
If you're buying that BS Patrick.....give me a call I more **** to sell you!!!
Seriously though, good timing on finding it. You would hope it would have resulted in a blown fuse but it could very well have been worse.
Old Sep 10, 2009 | 06:37 AM
rffhunter's Avatar
rffhunter
Found mine laying on the exhaust. Didn't know it was there till I smelled it burning. Caught it before it shorted on the pipe.
Old Sep 10, 2009 | 07:45 AM
WS6 Formula's Avatar
WS6 Formula
You could mount it so it doesn't happen again.
Originally Posted by WS6 Formula
Run wires directly to the battery (use Loc-Tite). To make a quick connect / disconnect you can solder wires to a banana jack and mount it some were out of sight. Use an additional banana jack on the Battery Tender leads. http://shop3.frys.com/product/237909...H:MAIN_RSLT_PG
Old Sep 10, 2009 | 07:53 PM
PKellyMc's Avatar
PKellyMc
That's a great setup, Jimmy. Well hidden, but easily accessed.
Old Sep 10, 2009 | 08:08 PM
maddghost's Avatar
maddghost
Mine is the same way. I had it rolled up under the battery cover for summer time untill a few weeks ago my starter clutch drive went out. The tek at HD popped it out the back of the box with the + cable and left it loose under there.I found it two weeks later when I was fiddleing with the pcV,mine ain't as gone as yours but not much better.
por2gezo
May 29, 2014 08:54 PM
toastman
Nov 30, 2009 11:00 PM
frankiefire702
Feb 24, 2009 10:46 PM
risdo
Apr 14, 2007 07:46 PM
FLHTPI01
Aug 22, 2005 09:44 PM
