head work
Old Sep 14, 2009 | 09:34 PM
SC-Longhair's Avatar
SC-Longhair
With the heads done and andrews 37...and 103, you'll definitely be well into 100 club.
Old Sep 15, 2009 | 09:26 AM
speedjunkie's Avatar
speedjunkie
I'm running 10.5-1 on 91 octane with t-man 590 cams. NO detonation! No excess heat either. Also another vote for CR.
Mike
Old Sep 15, 2009 | 06:12 PM
07 dyna man's Avatar
07 dyna man
Mike
hows the bottom end holding up im concerned about mine evereyone says they have weak crank bearings r u running the stock clutch mine started slipping when i grabbed 2cnd and third gear
Old Sep 15, 2009 | 08:35 PM
speedjunkie
Bottom end is holding up fine so far. I made sure the runout was good before the build, and no problems in 6500 miles. No, I put the same clutch setup in that you have. Sucker starts getting old fairly quick in stop and go traffic don't it!
Mike
Old Sep 15, 2009 | 08:48 PM
07 dyna man
Mike
you got that rite, i took the pivot pin out of the lever and held the clutch cable straight up and dripped half a tube of that harley lube into it its that stuff that looks like a syringe needle made a big difference you should try it
Old Sep 15, 2009 | 10:40 PM
Centerline's Avatar
Centerline
tareing the engine down to do sum port work and bumping up the compression to 9.6to1 the builder is trying to talk me into 10to1 is anyone having detination issues with 10to1 and will there be that much more gain with the higher compression ratio
I'm running 10.5 compression in my bike. NO DETONATION issues. I run premium fuel from the top tier companies... Shell, Exxon, etc. when the temps here in Texas are over 90 degrees. I run the mid grade fuel when temps are less than 90 degrees. The engine is also equipped with an oil cooler.
Old Sep 16, 2009 | 06:20 AM
redrubicon2004's Avatar
redrubicon2004
I notice alot of people saying they are running +10:1. One thing you have to remember is that compression and cams go hand and hand. Fuel also plays a role, but if you do 10.5:1 with an andrews 37 cam you will have headaches. Just make sure you stay within the cam manufacturors recommended compression ratio.
Old Sep 16, 2009 | 08:34 AM
speedjunkie
I lubed it once, and that helped a bunch, it's about time to do it again tho.
Mike
Old Sep 16, 2009 | 10:12 AM
07 dyna man
dude.thats a great pic. looks like u r rite down on ur boot and foot peg, you probally have spare ones lol
Old Sep 16, 2009 | 12:52 PM
paul s's Avatar
paul s
That was a factor with me going with the 37's, I didn't want that much compression, I know it makes more power but the fuel quality is going downhill. I've seen a few people having problems already.
donk_316
Engine Mechanical Topics
30
Feb 18, 2019 12:19 PM
cdorsey50stang
Exhaust System Topics
Sep 5, 2012 06:14 PM
Brettfullthrottle
EVO
Jul 6, 2010 12:35 AM
JCK
Oct 3, 2009 12:02 AM
pilot1996
11
Aug 31, 2005 05:49 PM
