Dyna speedo relocate done !
Old Sep 21, 2009 | 12:25 PM
JRK5892's Avatar
JRK5892
man that looks awesome!
Old Nov 12, 2009 | 07:36 AM
rounder's Avatar
rounder
Originally Posted by US66harley
Finally finished it up. I relocated my speedo for under $75 dollars and kept a stock look (kind of) Here is how it came out. Cleared the stock tank height with very small spacers. All I bought was some fiberglass, wrinkle paint, The bracket (#7 from below diagram), grommet (#6 from below diagram), two spacers and two longer bolts. No re-wiring required and all wires are long enough. I did drill another hole in the stock backplate to run the wires out of.
Looks to me like you could grind the guides inside the bracket down and install the bracket upside down so it sits flush with the top mount. Would look cleaner for those with tall risers.
Old Nov 14, 2009 | 08:27 PM
wes mullen's Avatar
wes mullen
Nice job, looks much better than stock
wes
Old Nov 15, 2009 | 11:19 AM
swampfox_csa's Avatar
swampfox_csa
Thumbs up Very nice.
Great job. The work is clean and the look shows some vision. I'm impressed.
Old Jun 12, 2010 | 03:25 PM
FXD101's Avatar
FXD101
6th Gear
Here are some pics and links from other post I used for ideas:
I also fiber glassed a cover for the wiring using the stock piece.
Heres the how to: Thanks Collide
https://www.hdforums.com/forum/sportster-...version-5.html
Thanks danfino
https://www.hdforums.com/forum/dyna-glide...ml#post4994281
us66harley - I like how your lower bracket looks. Do you know if the bracket you used (part #67084-96) will fit an 07 FXD speedo? Also, could you put photos back on of your assembly and parts? The ones on before are not there any more. Thanks a lot!
Old Jun 13, 2010 | 08:36 AM
US66harley's Avatar
US66harley
If the top is the 3-1/2 speedometer it will fit. I would assume so because the bracket is a '96 part number. Pictures should be back.
Old Jun 13, 2010 | 07:24 PM
pkdels's Avatar
pkdels
nice job i like the
Old Jun 13, 2010 | 07:25 PM
pkdels's Avatar
pkdels
look of it
Old Jun 14, 2010 | 06:29 AM
FXD101's Avatar
FXD101
6th Gear
thanks for the pics and response - I appreciate it!
Old Jun 14, 2010 | 12:45 PM
97 superglide's Avatar
97 superglide
Stage II
what about the tach?
