Just washed my bike, went to fire it up and it wont start. Get a weird noise, almost like the battery is fried, however lights/alarm/fuel pump still work fine. Video is coming soon, just loading it on you tube.
First actual run problem I've had with it, and not sure what to do.
Those are pretty low readings. When you put a load on it, wonder what the readings would be. It's gonna draw it down. I didn't listen to your you tube.
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Battery voltage should be higher than that. I agree with Super; sounds like loose cable or low battery firing the relay but not enough Oomph to drive the starter.
In case you're wondering, that chattering sound is your starter solenoid bouncing back and forth because theres not enough voltage in the battery to keep it locked up in one position.
