Extended Shifter Lever
Old Jun 20, 2006 | 10:51 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default Extended Shifter Lever
I just bought the extended shift lever (1 3/4" longer than stock) from Dennis Kirk so my new boots easily fit under it. Anybody tried one of these on the mid controls??
Old Jun 23, 2006 | 12:52 AM
KBFXDLI's Avatar
KBFXDLI
Default RE: Extended Shifter Lever
I just put it on.........boots fit fine.....10 minute job.
Old Jun 23, 2006 | 05:19 AM
jv225's Avatar
jv225
I bought the extended lever to use with my forwards. When I adjusted it as low as I wanted it would hit my forward control bracket before it would go into first. I ended up grinding a notch in the bracket so the lever would clear then I sent the brackets out to get chromed. Lucky it was winter here so the down time wasn't too bad. It is a lot more comfortable with the extended lever.
D Mucha
Mar 15, 2017 11:19 PM
darylnj
EVO
Nov 14, 2013 12:39 AM
philbun
Jul 25, 2011 03:07 AM
socobandit
Ironhead
Mar 30, 2007 06:22 PM
Droop
May 25, 2006 11:11 PM
