handle bar question.
Old Sep 22, 2009 | 10:29 PM
ambrose's Avatar
ambrose
Default handle bar question.
I just installed my new bars on my 2008 superglide and now when I press the front brake and the back brake the right signle light comes on, is it possible that I crossed up a wire? Should I pull the switch connectors from under the tank again? Any ideas?
Old Sep 22, 2009 | 10:31 PM
78fxs78's Avatar
78fxs78
Get a 12v test light and check your juice before guessing.
Old Sep 22, 2009 | 10:32 PM
archergodwin's Avatar
archergodwin
Safe bet you got a couple wires in the wrong hole. Better to pull the terminals out and try again....
Do you have the electrical service manual?
Old Sep 22, 2009 | 10:34 PM
ambrose's Avatar
ambrose
Ya I got a service manual but it is hard to read and understand.
Old Sep 22, 2009 | 10:47 PM
archergodwin
Okay... did you wire in some extensions in your wires, or just stock wires?
Old Sep 22, 2009 | 10:56 PM
ambrose's Avatar
ambrose
Ya I wired in 6 inch extensions to each wire.
Old Sep 22, 2009 | 11:07 PM
ambrose's Avatar
ambrose
I will have to take the switch apart tommorrow.
Old Sep 22, 2009 | 11:10 PM
archergodwin
As long as the extensions are in the middle, you should have the same stock wire going in and the same stock wire coming out right?
From my electrical service manual: (08)
Turnsignals: (both sides)
black = pin 1
brown = pin 2
blue = pin 3
Right side controls:
orange/white = pin 1
red/yellow = pin 2
green/yellow = pin 3
white/black = pin 4
white/brown= pin 5
red/black = pin 6
left side controls:
yellow = pin 2
blue = pin 3
white = pin 4
white/violet = pin 5
yellow/black = pin 6
black/red = pin 7
black = pin 8
Old Sep 22, 2009 | 11:11 PM
archergodwin
Just double check your terminal/plugs first. When I wired in my extensions, I made sure that the extension wires were almost if not completely external to the bars. I left the stock black plastic covering over the wires up to that point.
Old Sep 23, 2009 | 07:46 PM
ambrose's Avatar
ambrose
Thanks for all the help, it was one of the wires switched around, This site is the greatest and everyone is wounderful and knowledgeable.
ve9aa
Electrical/Lighting/Alarm
Sep 5, 2018 12:44 PM
mjolnir
May 14, 2012 08:03 AM
sammyshears
Oct 22, 2009 03:04 AM
Motorboatn SOB
Dec 1, 2008 11:59 AM
White-Trash
Aug 21, 2008 08:40 AM
