Just got mine today. Anyone else istall them in V&H side shots? How far in should they go? The instructions say "minimum 3" but generally speaking approx 6" from the exit is the sweet spot". I tried calling BCT (but they are closed for the day) to see if they recommended something a little more specific for the side shots. Just thought someone here with the same pipes may have contacted them for the info.
Actually you can't get the QQ six inches into the side shots (only about 5") ... they neck down to 1-3/4" just prior to the power chamber .... so just wondering should they go in as far as possible or leave them back a bit from where they neck down?
+1 put them in as far as possible
I would bet if you talk to BCT, I think it's Jim, he'll tell you the same
I actually just got an email response from BCT and they said to make sure that none of the cone (the QQ has a mesh cone that points toward the engine) extends into 1-3/4" portion (head pipe).
Thanks for the input guys ..... I just wanted to be sure before I started drilling holes and a big thanks to BCT for the after hours support. The snow will be falling in a few weeks here so gotta make the most of what little riding season we have left!
i put mine in at the correct 6" one pipe was close to the smaller size, but i ended up going back to the stock baffles as I lost to much top end power. (checked with GPS and tuned with Vtune on TTS)
I had some bct regulars installed as far as i could go, hated the sound and lost bottom end.
Switched ot bct qq installed in stock holes and its better, just my .02
