Tach install question
Old Sep 26, 2009 | 06:04 PM
paulies 07's Avatar
paulies 07
Default Tach install question
As soon as I get my 07 WG back I'm going to install an Barons tach. The instructions say the gas tank has to be removed to get to the wireing? is this true or is there an easier way? Thanks
Old Sep 26, 2009 | 07:17 PM
murphdog's Avatar
murphdog
You have to run the signal wire under the tank back to the ECM, but you can do that without removing the tank. You can pick up +12 and ground under the dash or you can run those wires under the tank back to the electrical panel. You'll have plenty of room if you take out the rear tank bolt and prop the tank up with a piece of 2x4.
Old Sep 26, 2009 | 07:26 PM
paulies 07's Avatar
paulies 07
Murph, thanks, I knew there was an easier way
Old Sep 26, 2009 | 07:37 PM
paulies 07's Avatar
paulies 07
brockb961
Audio Systems
Feb 16, 2013 10:25 AM
ALPHA_MALE
May 24, 2009 09:44 AM
ranman469
Dec 25, 2008 08:54 PM
hdjoe88
Jan 17, 2007 06:42 PM
ST Deuce
General Topics/Tech Tips
Jan 13, 2007 08:08 PM
