mini apes on a lowrider?
Old Sep 29, 2009 | 04:49 PM
dpriest's Avatar
dpriest
Default mini apes on a lowrider?
i've got a set of mini apes from last saint sittin around collecting dust.
im itchin to try them on my lowrider, does anyone know if my cables are long enough. if not and i need to buy new ones, i might go for taller bars. i already had to extend the wires when i put on my t-bars so that not a problem. i guess i'm gettin bored again.
thanks
dan
Old Sep 30, 2009 | 01:45 PM
dpriest's Avatar
dpriest
wow. i cant believe no ones ever done this. i guess i'll be the first.
yeay,yeah i know "use the search feature". i did but cant seem to get a straight answer. thanks
Old Sep 30, 2009 | 02:07 PM
bigdaddy33's Avatar
bigdaddy33
I'm pretty sure the cables are long enough to work with the mini apes, but since I've never tried it myself I can't be positive.
Old Sep 30, 2009 | 02:26 PM
bikerlaw's Avatar
bikerlaw
I put the Wide Glide baby apes on my Low Rider with no issues. I had to re-route a few things, but nothings tight, binding or retarded....except the owner. Seems like thats a popular issue now a days. Alot of people are installing them. I like the look, but more importantly, I'm just more comfy with moderately sized bars.
Old Sep 30, 2009 | 02:39 PM
kk6pg's Avatar
kk6pg
You can put the mini's on your 06 Low, but you'll be right there at the limit of what they can take. Your stock cables are 2 inches longer than a stock FXD, and that 2 inches is whats needed to get the bars on a Superglide. Remember, the cables that were originally used with those bars are 4 inches longer than what you have now. Give some serious thought into replacing them in the future. They will hamper setting the fall away when the time comes.
You dont have to listen to me if you dont want to. Try it and find out for yourself.
Old Oct 1, 2009 | 06:47 AM
dpriest's Avatar
dpriest
hey thanks alot guys
Old Oct 1, 2009 | 08:47 AM
lowriderrob's Avatar
lowriderrob
Hi dpriest.
I put mini apes on my '03 lowrider, from the stock bars. I also went from the longer stock push-back risers to shorter straight risers.
I clamped a straight edge to the top of the handle bars then had my son hold the bike up straight, and measured the height from the floor to the straight edge before and after the modification. This way I knew if would need new cables or not.
I also strongly suggest pulling the gas tank off.
With the tank off, not only does it make it easier to adjust the position of the throttle cables, but if you happen to drop anything or slip with a tool the tank won't get dinged.
The wires for both signal lights came out of the left side hole in the neck which made the wires for the right turn signal too short to double back around the neck.\
I didn't want to go cutting and splicing, so I took the right signal light assembly apart, and fed the wires and socket thru the hole in the right side of the neck (after removing the rubber plug), then reassembled it.
The throttle cables were long enough, I just had to reposition them but I did have to get a +6 clutch cable
When you research a clutch cable, there are a few dimensions you need to be aware of.
The overall cable length (the inside), the distance from the ferrule that goes into the clutch perch to the adjuster, and the overall lenght of the outer shield.
All in all it took me about 7 hours and a 6 pack.
Old Jul 7, 2020 | 03:24 PM
dtdbates's Avatar
dtdbates
Default mini ape size
Originally Posted by lowriderrob
Hi dpriest.
Hi lowriderrob what size are the mini apes you put on? I just purchased an 03 low rider from a coworker and it has the long pushback risers but Id rather have at least 12" minis. I'm trying to see if I can complete a straight swap with 12" or if I definitely have to re-run new cables. Any info on the mini apes you put on would be appreciated.
Old Jul 7, 2020 | 06:35 PM
Crazy's Avatar
Crazy
Sorry I can't answer your question. lowriderrob hasn't been on the forum for a few month's, so you might not get a reply from him.
I just wanted to say thanks for bumping this old thread. dpriest hasn't been on here for a long time, and I had forgotten how much I liked his bike. Nice to see a pic of it again.
Old Jul 15, 2020 | 12:09 PM
dtdbates's Avatar
dtdbates
Thanks Crazy, I appreciate it. If I eventually find out any details on a straight swap Ill return and post it on this thread. As of now I'm looking to replace the push-back risers with 1.5 or 2" straight risers with 10" or 12" mini apes. May take a bit before I can actually do anything, my son was born last Wednesday so my time outside of work is consumed with the newborn. Thanks again!
