Push Rods
Old Oct 3, 2009 | 11:57 AM
JCK's Avatar
JCK
Default Push Rods
Do I need to change my push rods when I change cams. Are can I just pull the stock ones an put them back on. Dont really want to spend another 200.00 .. Whats the deal..
Old Oct 3, 2009 | 12:13 PM
thedonthere's Avatar
thedonthere
No you don't have to but I would recommend getting tapered push rods.
Old Oct 3, 2009 | 01:35 PM
JCK's Avatar
JCK
Why? need info..
Old Oct 3, 2009 | 02:10 PM
kk6pg's Avatar
kk6pg
Originally Posted by JCK
Why? need info..
You're kidding, right?
tapered pushrods. Required for high lift cams. The stockers will rub, wear through, and eventually break. Is that enough info?
Old Oct 3, 2009 | 02:25 PM
SC-Longhair's Avatar
SC-Longhair
I know Im guilty of it too but give the OP a break...he asked an honest question. Not everyone is an engine builder or has experience doing so.
Second...the OP didn't mention anything about using hi-lift cams so why assume he will be.
Old Oct 3, 2009 | 02:35 PM
JCK's Avatar
JCK
If i new the answer I woulnt be asking.. Thanks for telling me why...
Old Oct 3, 2009 | 02:36 PM
kk6pg's Avatar
kk6pg
Thanks Vic. I'll withdraw my sarcastic remark.
I really do hope that if the OP's looking to do this himself for the first time, he has someone thats been through it before to watch over him. It's no fun to find out you've made a mistake when you dont know what it was when you did it. I think I remember reading the OP was going to use relatively mild cam. If thats the case, he wont need tapered, but using adjustable pushrods aint a bad idea. That extra couple of thousandths you pick up by using them over stockers is worth it for geting rid of the high rpm valve clatter.
Old Oct 3, 2009 | 02:42 PM
JCK's Avatar
JCK
Guys Just trying to figure this all out.. I dont want to make any dumbass mistakes..
Old Oct 3, 2009 | 03:45 PM
redrubicon2004's Avatar
redrubicon2004
I used the SE pro taper push rods in my build. They are pretty cheep and very compairable to the other brands. I think I got them from zanottis for $140? It is nice to be able to adjust if you want, and if you want to do a cam swap later on, you can do it without pulling the gas tank and rocker boxes.
I also replaced the lifters when mine was down. I used standard HD lifters, alot of guys use them in big dollar builds. 18538-99B
Old Oct 3, 2009 | 07:19 PM
reded's Avatar
reded
Get the SE adjustable pushrods, you'll save alot of time by not having to remove the tank and rocker boxes and wont have to buy new gaskets. They're worth it to me.
martin10
Engine Mechanical Topics
Dec 10, 2015 11:46 AM
Tat2u
27
May 2, 2015 08:32 PM
kbktulsa
Jun 5, 2013 03:50 PM
sg34
Jan 2, 2013 08:44 PM
rbbauer
Dec 29, 2011 06:27 AM
