Dyna Low Rider Windshield Recommendations
Old Jun 28, 2006 | 11:05 PM
dcrowley's Avatar
dcrowley
Stage I
Default Dyna Low Rider Windshield Recommendations
I'm a new Harley Owner and am interested in thoughts on which windshields work well on a 2006 Dyna Low Rider. I bought my bike with an HD touring windshield which got trashed when I dumped my bike last week (OUCH!). I rode the bike home without a windshield and discovered that it was a MUCH nicer ride without the windshield at speeds of less than 50. I have to believe that there's a smaller/more aerodynamic windshield out there that will give me better protection than my last one. The last one was quite upright and not adjustable and I suffered through quite a bit of buffeting and turbulance, even at slower speeds. FYI, I am 5'5" tall if that makes a difference.
Does anyone have any wisdom to share with me?
Old Jun 29, 2006 | 12:28 PM
grape ape's Avatar
grape ape
Default RE: Dyna Low Rider Windshield Recommendations
I have the HD quick detach super sport windshield on my Street Bob. It curves in a little and hugs the bike more than the other HD windshields, but still has about the same height. There is not much room for adjustment with this shield either, but the buffeting is minimal. I mostly notice it around the lower part of my face and nose if I notice it at all. I am 5/5" also by the way.
Old Jun 29, 2006 | 12:54 PM
but Ill try 2 try's Avatar
but Ill try 2 try
HD standard height clear on my streetbob. It's the quick detach and has a little adjustment room up and down on the forks. As far as wind buffeting I don't think their is any magic windshield that will eliminate all wind. Mine is definitely more comfortable with than without. You'll be amazed at what a good pair of riding goggles and ear plugs will do for you though.
Old Jun 29, 2006 | 02:40 PM
Keith_H's Avatar
Keith_H
5'6 or 5'7, i seem to be shrinking every year.
I have the HD quick detach low profile. Works great for me but I do get the wind underneath. From what i've read here i don't think you can stop that without other stuff like vests or lower guards. It slant's in some and directs the wind over my head just right. I can see over the top which is what i like. Just an inch or two height adjustment on the forks can make a big difference from catching the wind in your face to it going over your head. It's in the pic below but may be hard to see.
Old Jun 29, 2006 | 02:48 PM
grunt's Avatar
grunt
I'm 6'2 and have the quick-off. Works for me. You could try a Windvest shorty if non-HD parts are not a prob for you.
Old Jun 29, 2006 | 02:52 PM
smokermike's Avatar
smokermike
I have a memphis shades Deamon an for warmer weather I have a windvest im 5'9" both are great
Old Jun 29, 2006 | 03:32 PM
DelcoDyna's Avatar
DelcoDyna
Any windshield will produce a low pressure zone behind the shield. Air will come in to equalize the pressure differential (usually from the bottom). That's what causes buffeting and turbulance.
Personally, I don't use a shield - I like the taste of bugs.
Old Jun 29, 2006 | 04:10 PM
jt1965's Avatar
jt1965
I am 5'8" and have the standard height on my lowrider. I take it off if I am just tooling around town. But for the commutes I have it on. It does buffet from below quite a bit but if I put my feet straight out it seems to block a lot of it.
I would ride without it but the bugs are making me get fat.
TiRider
Sep 28, 2019 11:39 AM
danrad55
May 5, 2012 07:29 PM
DeweyB
May 20, 2010 10:28 PM
Fuente
May 20, 2005 09:37 PM
