Brake pedal on forward controls
Old Oct 16, 2009 | 11:02 PM
tophermatt's Avatar
tophermatt
Stage II
Default Brake pedal on forward controls
i recently installed fwd controls on my 08 FXD. The brake pedal seems to sit at an awkwardly High position and I have to take my foot off the footpeg to engage the rear brake. Anyone know if it can be rotated clockwise closer to the ground? How does the process go?
Old Oct 16, 2009 | 11:07 PM
OhioSkully's Avatar
OhioSkully
the rod that connects the brake pedal to the rear master cylinder can be screwed in more and that would pull the rod back further and pull the pedal down more. if you look at the pedal the rod is connected follow it back and loosen the nut on it take the rod loose from the pedal and screw the rod in more it may get you what you need.
Old Oct 17, 2009 | 01:34 AM
WS6 Formula's Avatar
WS6 Formula
Use two wrenches and break loose the jam nut (the spin nut to the right). Then the nut on the left can be rotated to adjust pedal location.
Old Oct 17, 2009 | 02:11 AM
OhioSkully's Avatar
OhioSkully
ya what he said thats the easier way lol had to many beers and i was trying to make it hard on you lol
Old Oct 17, 2009 | 07:36 PM
tophermatt's Avatar
tophermatt
Stage II
Default ill give it a shot
Thanks, I understand, I'll give it a turn and see how that helps.
TxAnthony
Jan 7, 2017 03:48 PM
C908
Dec 28, 2009 05:45 PM
Handycam
Mar 17, 2009 11:46 AM
Robottom
Jan 19, 2009 02:58 PM
Cory
Jun 13, 2006 01:08 AM
