Footpegs VS Floorboards
Old Nov 3, 2009 | 05:53 PM
pockets2000's Avatar
pockets2000
Originally Posted by sergeantmajor
I 've been riding an FXDC '07 for the past two years and i always enjoyed the stretched leg position of my forwarded footpegs.Great chopper feeling.
But when on long rides there are problems for me:
Legs dropping because of the vibrations or bad road.
On high speeds due to wind a had to press me feet hard on the pegs.
Slippery shoes which didn't like to stay in place.
And knees opening when completely relaxed.
I recently rode on a softail haritage and i was amazed by the fact that all my problems were solved.
I'm reall thinking of installing floarboards now.
Can it be done on a Dyna?
Anyone knows if H-D has a such a kit?
Any other aftermarket maker in mind?
Thanks for any tip
https://www.hdforums.com/forum/dyna-...r-dyna-19.html
Go to the above link and see pages 13, 14 & 15. There are complete instructions and parts list for the conversion I did. Basically the right or brake side will all mount up perfect, no modifications needed. The left or shifter side is the problem. I personallly feel that what I did with the Shifter is about as clean and factory looking as they come. I am very happy with this. Have had it the full riding season this year.
Old Nov 3, 2009 | 11:08 PM
firebrick's Avatar
firebrick
i put on the two orange harley floorboard and nearly took them off. i was having too much problem with the fact that my legs kept wanting to go off the sides of them, knees opening up like you stated. i put a piece of tin in the space where they pivot and now that they are slightly angled up toward the bike, i love em
Old Nov 3, 2009 | 11:19 PM
RonnR's Avatar
RonnR
Originally Posted by sanlyn
Have the Kuryakyn Boards on my FXDF ... very comfortable.
Same here, very good...
Old Nov 3, 2009 | 11:35 PM
danktat's Avatar
danktat
I ended up not using the extra adjustment arm when I installed mine. It sat my legs out a bit too far. I found that height wasn't an issue anyway and the angle could still be adjusted from the male adapter and the board itself. I like the fact that there is the "option" of using that adjustment arm but no "need" to have it in place in order for it to work
Old Nov 3, 2009 | 11:52 PM
SURFOR Chop's Avatar
SURFOR Chop
I posted a few photos and description of how I installed Softail floorboards on my '05 FXD at https://www.hdforums.com/forum/dyna-...na-photos.html.
I felt about like you sound ... I had tried 'stirrups' (heel rests) with my forward controls ... helped some, but still a little dissatisfied ...
After having ridden a few bikes with floorboards, just thought to myself: man, that is way more comfortable ... I should get me some of them ...
So I did ...
R/
'Chop
Old Nov 4, 2009 | 09:02 AM
firebrick's Avatar
firebrick
i did the same thing you did, didnt use the adjustment arm, i had no problem with the toe angle front to back but i wanted the boards to actually toe in towards the bike a little instead of sitting flat. this way i can put pressure on the boards, my feet dont try to slip outwards and it keeps my knees in, so much more comfortable now.
Old Nov 4, 2009 | 09:09 AM
Andjh123's Avatar
Andjh123
+1 on the pegs with heel rests and +1 on the combined mid and forward pegs for changing leg position on long trips. Has anyone with floorboards noticed an issue with reduced lean angle? When I initially put the pegs with heel rests on the mid controls, I was having issues with scraping the pegs due to the slightly longer peg length, so I switched them up to the front/highway position and put the stock pegs back on the mids. I imagine footboards in the forward position might not have as much of an issue with scraping as footboards in the mid position?
Old Nov 4, 2009 | 11:45 AM
SURFOR Chop
Floorboard scraping can be a little unnerving the first time ...
After that, you just learn when to expect it or to compensate a little to avoid it ...
I found that the floorboards cut into my lean angle a little, but for me the small trade off is definitely worth it ....
One of the previous posts mentioned something about some floorboards don't look 'right' or whatever ... I kind of felt that way too ...
That was one of the reasons I went with the Softail boards ... it is the MoCo's OEM design for Softails, so they have a 'factory' look to them and its not that hard to find the parts ... there is a plethora of aftermarket boards, shifter levers, brake pedals, chrome, black, etc., etc. that can be used depending on taste and personal preference ....
R/
'Chop
Old Nov 4, 2009 | 03:54 PM
rounder's Avatar
rounder
Originally Posted by kpolak
I have the Kuryakyn Stirrups under the pegs, and they are very comfortable, if you're looking for options other than the boards.
I would recommend these as well. Made a huge difference for me over pegs alone.
Old Nov 4, 2009 | 04:28 PM
ElusiveThorn's Avatar
ElusiveThorn
I purchased my Dyna for one reason for not having floorboards. I do love the look and comfort to my heel rest.
