Problems bike would not start speraticly today
Old Nov 8, 2009 | 10:22 PM
antman27's Avatar
antman27
Default Problems bike would not start speraticly today
Hello all What a stressful day speraticly my bike would NOT start and the alarm light would flash
So I grabed my other key/fob ( thought the fob may have a problem)
When out riding my friend said my tail light was not working speraticly the break light was working
BUT than it came back on
At our last stop it took almost an hour to start it - disconected the bat to see if that would reset something took off the seat and checked all conections with no luck-
Anyone think it could be as simple and the bat is low in my fob not alowing the bike to start - that dont explain the tail light but WTF ????
Old Nov 9, 2009 | 01:37 AM
PigInaBlanket's Avatar
PigInaBlanket
Yes my battery was low in my fob and it would sometimes let me start it then sometimes not. Put a new battery in (well used out of a computer) and it has been fine since. No idea about the tail light problem though.
I see you used another fob and you still had the problem? Maybe not a battery problem then but still I'd replace the battery, it's cheap anyways.
Old Nov 9, 2009 | 04:32 AM
icecaps's Avatar
icecaps
Reading More Posting Less
Check and clean your fuses and relays.
Had issues with the bike starting and found corrosion on the relay's connectors. The fuse cover isn't exactly water tight.
Old Nov 9, 2009 | 07:21 AM
dyna07custom's Avatar
dyna07custom
+1 if your sure battery con are good thats the next place i would look
Old Nov 9, 2009 | 09:09 AM
antman27's Avatar
antman27
The bat is clean and tight
I am thinking it is something with the Security system since the lights are flashing and the start switch has no power
We tryed push starting it the motor turned but would not stay running
Old Nov 9, 2009 | 07:12 PM
antman27's Avatar
antman27
Nobody else ever have this problem with the Security system not alowing you to start the bike and the Security system light flashing flashing ?
Old Nov 9, 2009 | 07:38 PM
Lama's Avatar
Lama
Mine did it the other day when the bike was cold, I had to wave the keyfob around the fuse box to get it to connect with the security system antenna. I do not like this system, anyone know how to deactivate the security module?
Old Nov 9, 2009 | 07:53 PM
antman27's Avatar
antman27
I do not think the cold temp had anything to do with it
I rode in 40 drg last season with no problems
Old Nov 9, 2009 | 07:59 PM
maddghost's Avatar
maddghost
Did you try by-passing the security system?? That would let you know wether or not the fob ws fk'd. It seems more like you have a short somewhere, like the others said check your fuse box for moisture,check all fuses if needs be. If the start switch has no power it may be that the short is there.
Old Nov 9, 2009 | 08:08 PM
antman27's Avatar
antman27
I did not try and bypass security system I do not know how to do that BUT would give it a try once I find out how
