Problems bike would not start speraticly today
Old Nov 10, 2009 | 02:14 AM
Mr Cujo's Avatar
Mr Cujo
Don't know if it helps, but my Ultra was doing the same/similar thing.
Changed fob battery, thought it was fixed, but nope..
Tested and diagnosed as a bad starter. Intermittent fail.
Actual cause turned out to be loose starter bolts.
Old Nov 10, 2009 | 05:18 AM
maddghost's Avatar
maddghost
Originally Posted by antman27
I did not try and bypass security system I do not know how to do that BUT would give it a try once I find out how
It's all in the little manual.I would scan it for you if I had a scanner. If it's the factory settings the combo is all 1's .It is all 1's in canada.
Turn your ig sw. on and quickly hold both turn signals. when the combo starts flashing. enter the number with the left turn sig by repeatedly pressing until the number is right, press left turn sig to enter and move the digit.. after all 5 nums. the sec. is de-activated temporarily until the ignition is switched off again.
Old Nov 16, 2009 | 06:38 PM
antman27's Avatar
antman27
Update
I was out all day yesterday -I Changed fob battery and never had a problem yesterday The bike started every time I still dont feel comfortable that it was just a battery
Old Nov 16, 2009 | 06:46 PM
2003Springer's Avatar
2003Springer
Batteries do some strange things. Almost Ghostly......... B000oooo
Old Nov 16, 2009 | 08:38 PM
RCB's Avatar
RCB
Check the connection to your TSSM. Turn Signal Security Module
bigmikaele
Jan 28, 2023 02:00 PM
rick rocker
May 3, 2018 09:17 PM
Timmy B
May 22, 2014 10:19 AM
MikeBel
Sep 29, 2011 09:23 AM
883 IRON
Aug 10, 2009 12:57 AM
