Anyone have a problem mounting the True Track with an Engine Guard?
Old Nov 9, 2009 | 12:02 PM
Mike Horrell's Avatar
Mike Horrell
Default Anyone have a problem mounting the True Track with an Engine Guard?
The mechanic who is installing the True Track called me and said that it will
interfere with the Factory Engine guard installed on my 2009 FXDC.
There's nothing on the website or in the installation instructions about this
and I've never heard anyone mention it before..
Is the mech misinterpreting the installation guide?
Old Nov 9, 2009 | 12:22 PM
MonteW's Avatar
MonteW
It is true. It is impossible to mount True Track with H-D Engine Guard. I had to modify the bracket on the right side (i.e. cut-off the original and weld the new one).
Old Nov 9, 2009 | 01:59 PM
Mike Horrell
That really sucks.
I've been emailing and talking to the folks at True Track and I'm waiting to see
what they have to say. I've got an idea, but I'm not sure if there is enough "meat"
on the guard's mounting flange to make it work.
Right now I am not a happy camper.....
Old Nov 10, 2009 | 02:31 AM
grbrown's Avatar
grbrown
I don't know how Dynas have changed over the years, but I fitted the TT kit to my 03 Dyna, with the factory guard in place, with no problems. I don't have forward controls, are they part of the problem?
Old Nov 10, 2009 | 09:40 AM
Mike Horrell
No, the problem is the actual right side frame attachment. The True Track and
it interfere with each other.
Pictures HERE...
http://www.picturetrail.com/sfx/album/view/22699122
The folks at TRue track have been very helpful, but the only solution is to whack
off the right side mount and rework it to give more clearance by having the u-bolt
relocated. Unfortunately, there is not enough "meat" on the bracket to just drill
another set of holes; I'm going to have to have a new piece made.
Life........... <shrug>
In this photo, you can see where the link hits the guard mount. When the TT
is tightened into place, (it's loose in this photo) the link head is exactly where
the guard flange and bolt are.
BTW, HD's Dyna-specific oil cooler also can not be used with a True Track;
it attaches in the space occupied by that big forged arm.
Old Nov 10, 2009 | 09:59 AM
grbrown's Avatar
grbrown
Mike,
I see the problem! My guard has integral brackets and fixes where your forward controls are, on the outside of the lower frame tubes, so they are well away from the TT mount you show. Are you sure your guard is a Harley factory one?
Someone on HDF has posted photos showing how they got their oil cooler to fit on with their front TT, so worth a search back if you can find it.
Since you've shown me yours, I'll show you mine:
Attached Thumbnails Anyone have a problem mounting the True Track with an Engine Guard?-truetrack-dyna-front-stabilizer-f.jpg
Old Nov 10, 2009 | 10:04 AM
grbrown's Avatar
grbrown
Mike,
Admiring my post reminds me of something. There is a lock-nut and bolt on the lower mount, which is supposed to be set up with some clearance. I found the nut was difficult to get a spanner/wrench on and the darn bolt unscrewed and locked the whole thing solid! Engine vibrated like you cannot imagine. I had to partly dismantle the thing, to sort the bolt out, and then just screwed it in very tight, to fill the hole. Hang the clearance, which I could see no purpose for anyway!
Old Nov 10, 2009 | 10:11 AM
Mike Horrell
Hi, GR;
Yes, that's the jen-you-whine official Harley engine guard for the 2009 Dyna. I
bought the bike while it was still in the box and had to be assembled at an
out-of-town dealer, then went to the local stealer's (note difference in spelling,
it ain't accidental) parts department and got all the accessories straight from the
parts bin.
I'll have to look for that oil-cooler post. I haven't decided if I need one or not, but
I'd like to know how to do it if necessary.
Old Nov 10, 2009 | 12:36 PM
rounder's Avatar
rounder
As far as the engine guard... toss it..... oil cooler ...Jagg make a beautiful cooler that will mount on your left frame downtube.
Old Nov 10, 2009 | 02:23 PM
Mike Horrell
Originally Posted by rounder
As far as the engine guard... toss it..... oil cooler ...Jag make a beautiful cooler that will mount on your left frame downtube.
Nope, those bars are too handy.
I'm not familiar with the Jaguar set-up (thanks for the tip) but I've seen
similar concepts and I'll definitely look into that.
