crankcase breather filter pix
Old Nov 15, 2009 | 12:35 AM
74c10sb's Avatar
74c10sb
Default crankcase breather filter pix
just wanted to get some opinions on the looks good bad all comments welcome
Attached Thumbnails crankcase breather filter pix-100_1881.jpg   crankcase breather filter pix-100_1876.jpg   crankcase breather filter pix-100_1873.jpg   crankcase breather filter pix-100_1884.jpg   crankcase breather filter pix-100_1883.jpg
Old Nov 15, 2009 | 09:04 AM
mud's Avatar
mud
Looks fine. nice clean execution.
Got a picture from farther back showing the whole engine on the pipe side??
Also, I'd like to see a shot like above, but showing the breather bolts.
Old Nov 15, 2009 | 12:57 PM
74c10sb's Avatar
74c10sb
its an a/n b/s air cleaner i used some high heat metal epoxy to block off the internal breather passages. the fittings can be found at any industrial hardware store. i just fallowed your how to in the under 50 bux
Attached Thumbnails crankcase breather filter pix-100_1885.jpg   crankcase breather filter pix-100_1888.jpg   crankcase breather filter pix-100_1886.jpg   crankcase breather filter pix-100_1889.jpg   crankcase breather filter pix-100_1890.jpg
Old Nov 15, 2009 | 01:44 PM
mud's Avatar
mud
its an a/n b/s air cleaner i used some high heat metal epoxy to block off the internal breather passages. the fittings can be found at any industrial hardware store. i just fallowed you how to in the under 50 bux
again nice job.
and good to hear the Under 50 bux posting helped you out.
............quarter million hits on that thread.
Old Nov 16, 2009 | 03:56 PM
mplecha's Avatar
mplecha
do you happen to have a direct link to that post? I've been trying to search, but have come up with not much so far. thanks!
Old Nov 16, 2009 | 04:41 PM
JT-FXDL's Avatar
JT-FXDL
Have you tried this route? Not a direct link but itemized may help you find it:
https://www.hdforums.com/forum/dyna-...ml#post2835532
And by the way, Mud, awesome job putting this together. I've been studying these links lately. I wish this was the link in the sticky.
Joe
Old Nov 16, 2009 | 05:23 PM
JRK5892's Avatar
JRK5892
looks good... i am not such a fan of the filter on both sides, reminds me of the virago's a bit... but very well done on the breather lines... hve you though about hiding the filter down by the starter or doing a catch can?
Old Nov 16, 2009 | 05:46 PM
mud's Avatar
mud
mplecha, I think I have the correct direct links below........
Joe
Thanks for the compliment Joe. Appreciate it.
I think these below are the direct links to info on crankcase venting....
Under 50 bux posting #125...........
Under 50 bux posting #981.............
I think there is one more, need to look for it.....
Below two pix using different routing for my current rerouting.....
Old Nov 16, 2009 | 06:29 PM
rounder's Avatar
rounder
cool, but, won't that open filter breather allow the oil to eventually get out all over the primary?
Old Nov 16, 2009 | 11:10 PM
74c10sb's Avatar
74c10sb
joe- thanks yeah i may do something like that later im always changing something
rounder- i run my bike on the low side of the safe range so oil blow by has never been an issue
Bowhunter8607
Sep 13, 2020 09:42 AM
kontiki
Aug 20, 2016 12:48 PM
team423
EVO
Jan 24, 2014 07:31 AM
gseely
Sep 24, 2012 07:41 AM
El Chiguete
Exhaust System Topics
Nov 1, 2011 01:30 AM
