new guy for a Dyna
Old Nov 17, 2009 | 07:12 PM
mashedpotatoes's Avatar
mashedpotatoes
6th Gear
Default new guy for a Dyna
I'm going to look at purchasing a 2000 Dyna Superglide tomorrow. It hasn't be started in three years, but I am told ran perfectly before the owner's father passed away (he was the rider). It has only 9,000 miles on it, which is nice. The pictures I've seen of it are immaculate, so it seems promising. She told me someone at a Harley dealer told her to drain all of the old gas, swish new gas around inside the tank three or four times, and then fill it up and try to start it. She said she has no idea how to do any of this, so I offered a little bit of my time to try to help, figuring I'll be able to talk her down a little bit if I decide to purchase the bike. I was wondering if I should do anything else to the bike before trying to start it. I thought it might be a wise idea to change the oil before starting it, but wasnt sure if it would be worth just doing the gas, starting it and letting it run for only a few to know that it does, and then do the oil and other fluids on my own time.
Another idea I had, but I am not sure how valid a test it would be, is to take the plugs out and look at their condition. I figure it could give me a clue as to how the bike was running before it sat. I've ridden sport bikes for past years so I'm not too familiar with the intricacies of Harleys, so any help is welcome. Thanks guys and gals.
Old Nov 17, 2009 | 07:38 PM
jason628's Avatar
jason628
Greetings,
You might have to rebuild the carb...I'll bet gas has been sitting in it and has turned to varnish. I'd also look at the tires for cracking. Old tires can be very dangerous. Of course you'd probably need a fresh battery as well. Good luck!
Old Nov 17, 2009 | 07:43 PM
jarhead45's Avatar
jarhead45
Originally Posted by jason628
Greetings,
+1 on the battery. Got my sons after sitting up for 3 years... Dead battery.
Old Nov 17, 2009 | 07:47 PM
HDDyna2006's Avatar
HDDyna2006
Don't know about jumping battery on bike, better to take out to Autozone, Oreilly's to get it tested and charged before you start cranking.
Old Nov 17, 2009 | 08:08 PM
sharkey's Avatar
sharkey
Fresh gas and fresh battery; don't melt the starter; hope it's "warm" before you try to start it (ie not 40 degrees...) should hear it catch real quick if there's gas where it should be...be nice...be patient
Old Nov 18, 2009 | 07:55 AM
rjmac53's Avatar
rjmac53
good luck with it and enjoy...
Old Nov 18, 2009 | 08:02 AM
dyna rider's Avatar
dyna rider
Default First Start
I would pull the plugs and squirt "Sea Foam" in the cylinders as well as changing the oil.
2011FLHTK
Aug 30, 2016 06:35 PM
ramu3527
May 11, 2015 09:47 PM
danny1975
Shovelhead
24
Sep 10, 2014 09:47 PM
PigInaBlanket
Feb 19, 2013 09:08 PM
Come&TakeIt
Shovelhead
17
Feb 21, 2011 07:54 AM
