fx sliders
Old Nov 21, 2009 | 10:26 AM
capnez's Avatar
capnez
Default fx sliders
I have a 2003 fxd and came into a set of I think fxr? front end with a mag wheel and twin
disk or dual rotors will they fit.I want to powder coat them and install.
please help
Old Nov 21, 2009 | 04:07 PM
GeorgeJ's Avatar
GeorgeJ
please help
Does the front end have adjustable forks (flat head screw) adjusters on top? If so then this is a FXDX front end (great score) and it will bolt right up. You will need a larger master cylinder to accommodate the additional push needed for both calipers.
If it's older then FXDX- pre-99 it should fit as well. The difference would be in which calipers bolt up to the legs. Pre-99 I think are single puck and the lowers may not work with 99 and newer calipers.
Hope that gets you started.
George
Old Nov 22, 2009 | 11:41 AM
capnez's Avatar
capnez
ty for info. I think it is fxr and I will have install whole front end.I have the calipers trip trees etc,not sure about speedo hook up
Old Nov 22, 2009 | 12:06 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
please help
Here's a link to Bikebandit.com oem parts diagrams. You'd compare the set-up of some older FX's to the 2003 model using these diagrams. I hope this will help you out on this issue.
FXD2003Rider
Tee&Vee
Shovelhead
21
Mar 22, 2016 09:10 AM
mlbeggs
EVO
Jun 1, 2012 06:42 AM
RideRigidPan59
Shovelhead
Jan 2, 2012 11:15 AM
WidowsSons
Wheels/Tires
Mar 8, 2009 09:54 PM
Musky
Feb 8, 2006 08:51 PM
