Check Engine.
Old Nov 24, 2009 | 12:14 PM
CRZYLGZZ's Avatar
CRZYLGZZ
Default Check Engine.
Hey guys, its me again, this is a simple question, and I'm looking for direction again.
I'm wrench savy so I'm not in panick mode, but with my scoot, I'm not to sure, its a combination of nerves,and unfamiliarity.
When I start my scoot, the "Check Engine" light lights up, stays on for a few minutes, then shuts off.
Is this a periodic maintenance reminder, or a sign of a more problematic issue brewing.
I don't notice or feel any problems with my ride in anyway. I'm just curious/ concerned.
My mileage is just shy of the 5k mark.
Ok guys Hit me.
Old Nov 24, 2009 | 12:16 PM
Sapper-0503's Avatar
Sapper-0503
Run the digital DIAG test - I dont have the thread on hand.
Old Nov 24, 2009 | 12:18 PM
Sapper-0503
https://www.hdforums.com/forum/dyna-...lear-them.html
Old Nov 24, 2009 | 01:19 PM
CRZYLGZZ's Avatar
CRZYLGZZ
Sapper, just did it. I got 3 codes, 2 of which are self explanatory cause of my Power Commander.
The 02sensors.
But I also got code P0505. Idle control Valve.
Yikes. Is that a Problem?
Old Nov 24, 2009 | 01:29 PM
Sapper-0503
If the other two are related to your PC also, try re-flashing your map.
Old Nov 24, 2009 | 01:31 PM
Sapper-0503
...after you reprogram your PC follow the instructions in the other thread to purge your errors and then re-run the tests.
What factors where involved to cause the change/errors?
Old Nov 24, 2009 | 01:33 PM
Sapper-0503
Sorry just saw the O2 Sensor part. You shouldnt get errors for the O2 sensors, even if they are still connected and not terminated.
Old Nov 24, 2009 | 02:01 PM
CRZYLGZZ's Avatar
CRZYLGZZ
No, they're disconnected. I naturally assumed the ECM flashed a code cause it didn't read.
The codes I got were P0373, and P0374
I recently updated my firmware to my PC. Not the MAP, but the firmware. Could that be a problem.
Secondly, would the Check Engine light come on, then go off for like a maintenance reminder
Old Nov 24, 2009 | 03:46 PM
CRZYLGZZ's Avatar
CRZYLGZZ
Any ideas???
Old Nov 25, 2009 | 07:15 AM
CRZYLGZZ's Avatar
CRZYLGZZ
Bump for more input, when I get home tonight, ill reset the codes.
Just wondering if there are any other issues that could set off the Codes.
