Ape Wiring
Old Nov 29, 2009 | 01:01 PM
06BlackBob's Avatar
06BlackBob
Default Ape Wiring
I've heard that there's enough wiring in my 06 street bob to do internal wiring on 16'' apes without buying an extension kit. Is it true?
Old Nov 29, 2009 | 01:55 PM
jmpancoast's Avatar
jmpancoast
I don't believe you will find this to be the case.
I have a Super Glide, but have a set of switches and wiring from a Street Bob on it which I used to internally wire 10.5" Flanders mini-apes. Definitely not enough wire on the harness I used.
I think you are going to be looking at extensions.
Easy enough to pull the rubber grommets from the side of the neck, find the wiring harnesses, and see what you have to work with. May also have to pull the access cover from the bottom of the frame at the neck.
Old Nov 29, 2009 | 03:55 PM
rounder's Avatar
rounder
I would recommend the extention kit. Very easy to use... crimp pins together and shrink wrap.
Old Nov 29, 2009 | 04:38 PM
06BlackBob's Avatar
06BlackBob
just putting some quotes where I heard about the wiring...
Originally Posted by HOGRIDA_06
I went +6 on all mine and the clutch cable seems alittle to long. Your stock wiring should be plenty long enuff to run internally.
Originally Posted by fitztrain
yup stock wires will have plenty to run internal on 16s
But, I will check when I get my bike back tomorrow or Tues if I don't spend the whole time RIDING that sucker since I haven't seen it in like 3 weeks since my wreck
Old Dec 1, 2009 | 04:16 AM
fryejs's Avatar
fryejs
uh...No, believe it or not it will take more wire to run internally than it does on the outside, i dont have this setup but i did change out my 1" knuckle bars for 1 1/4" knuckle bars and i had to add wire. if you have to cut wires then i suggest going to parts store and getting 16 guage wire and cutting and soildering it in yourself. i found this to just be a "cheaper" way to get the job done, more to remember as far as colors go (write them down) but cheaper.
Old Dec 1, 2009 | 09:30 AM
spiritwarrior's Avatar
spiritwarrior
Let, us know how it goes. I want to internal wire my existing 08 Street Bob, Mini Apes.
Old Dec 1, 2009 | 11:22 AM
JRK5892's Avatar
JRK5892
no there is not enough, you are going to be about 4 inches short, i solded in extensions. took me no time
Old Dec 1, 2009 | 11:38 AM
Derv's Avatar
Derv
I'm just in the process of doing this - fitting a set of Buckhorn bars to my Dyna Low. So far I've ascertained that I'm going to be needing a new front brake line, clutch cable (that seems to be just about 2" short) and the switch wiring is too short. I'm taking the tank off tomorrow to see if I can pull a bit of spare through but I'm not very hopeful so it looks like I'll be making a new pair of harnesses up. Turning out to be a lot more expensive than I thought! Hey, the weather here's terrible so I can't ride it - may as well work on it I guess!
Derv
Old Dec 1, 2009 | 12:35 PM
akutz1's Avatar
akutz1
6th Gear
Derv im having the same experience. Im putting mini apes on my 07 Superglide. I originally ordered some street bob cables because i was told they would fit, they are about 4 inches short. Ordering custom cables today and pulling the tank off this weekend to see if i can squeeze an inch or 2 out of my existing switchwires. Not very hopefull.
This was supposed the be the cheap portion of my winter mods. Not so much.
Old Dec 1, 2009 | 12:56 PM
dpriest's Avatar
dpriest
doesn't the streetbob come with miniapes? so why would the cables be too short?
