question about removing triple trees for powdercoating??
Old Dec 1, 2009 | 04:30 PM
jmartin9721's Avatar
jmartin9721
Default question about removing triple trees for powdercoating??
hey guys, just wanted to see if anyone can let me know if i need any special tools to remove triple trees? hd service guy told a buddy of mine we needed to remove ignition lock to do this, which requires a special tool. looking in my manual, didnt see any reason why you'd have to remove that. anyone had any experience with this?
Attached Thumbnails question about removing triple trees for powdercoating??-059.jpg
Old Dec 1, 2009 | 04:38 PM
lhcstreetbob's Avatar
lhcstreetbob
no you dont need to remove the lock but you do need a torx sockets and a 1 1/2 socket for your stem nut
Old Dec 1, 2009 | 04:40 PM
jmartin9721
yeah, thats what i thought. didnt understand why that would need to be done. thanks!
Old Dec 1, 2009 | 05:03 PM
lstcause616's Avatar
lstcause616
mechanics like to tell people that to scare them away from doing the work themselves. just another way to generate more work for themselves.
Old Dec 1, 2009 | 06:32 PM
cactusred's Avatar
cactusred
oh and just in case you do decide down the road (you don't here for triple tree removal), remove that ignition lock on the fork, I conveniently saw in my hd service manual a handy tool with two or three **** (can I say that on here ) that spins the collar off the igntion assembly which is located behind that pretty little round placard (ign/acc/start/off etc).
BLA, you don't need it, I used a pin punch and gave it a slight tap, it rotated around and off from there, just food for future thought.
Old Dec 1, 2009 | 08:45 PM
HDDyna2006's Avatar
HDDyna2006
Are you sending it to Joe? He have a $150 front end special.
Old Dec 3, 2009 | 08:44 PM
jmartin9721
no, saw the offer. sounds like a good deal. called a place around here that does good work and the price is pretty close.
Old Dec 4, 2009 | 07:23 AM
Bobbed Out's Avatar
Bobbed Out
you just need to check for proper fall away when you put them back on i believe
Old Dec 4, 2009 | 01:23 PM
jstreet0204's Avatar
jstreet0204
Also if you have it on a jack. Make sure to put something under the back tire to support it when you take the weight off the front.
Old Dec 4, 2009 | 03:16 PM
gibbyflhx's Avatar
gibbyflhx
Depending on the Jack you dont need to do anything, I took 2 front ends off of touring bikes last winter and never supported the rear tire. I have a JS jack
