No left signals!!! HELP!
Old Dec 3, 2009 | 06:16 AM
vthokieharley's Avatar
vthokieharley
Default No left signals!!! HELP!
I need to get my bike to pass inspection, and for some reason, during my last ride the left signals quit working. I have changed the bars and grips, but all has been working well for 6+ months. I have a 08 Street Bob.
The key light started coming on, and the signals started flashing fast, then the key light stayed on, and no signals. I have tried to wiggle all wires, etc. and can get no response. Right signals work perfectly.
The ignition seems to be loose, but I do not know why this would affect the left signals. Any help is greatly appreciated.
Old Dec 3, 2009 | 07:05 AM
08fxdf43202's Avatar
08fxdf43202
My 08 FXDF did the same thing. The back tire had rubbed through the wiring for the rear turn signal.
You certainly have a bad wire connection.
Old Dec 3, 2009 | 09:40 AM
SUPER01's Avatar
SUPER01
Since you have changed out the bars, there may be a pinched wire somewhere. All it takes is vibration to finally cut the covering and then you get a short and the signal stops working.
I'd start looking closely at the wires first where the wires go thru the switch covers, easy to pinch them between the bars and covers.
You turn the key on and all four signals flash 6 times, correct?
There is a error code stored, not sure how to get it on the newer bikes but do a search on here and I'm sure someone has posted it. Once you fix the problem you will have to clear the code or the code will clear on it's own after 50 starts.
If the ignition is loose and goes bad nothing works, I've already replaced mine once.
Good luck - hope this helps.
Post up what you find out so you may help others out.
Old Dec 3, 2009 | 10:22 AM
NOZEM's Avatar
NOZEM
I've had had a wire rub on the back tire, it eventually shorted out and showed the same symptoms as you have. I don't know how to get the error codes either but just started checking all the wires. it sounds like you have a loose or broken wire somewhere. Good luck dude, I hope this helps.
Old Dec 3, 2009 | 10:28 AM
2003Springer's Avatar
2003Springer
This is the likely cause of the problem.. That is where I would start the search
Old Dec 3, 2009 | 11:29 AM
vthokieharley
Thanks all. I will be checking this afternoon...Hopefully it works, its the first time with no rain in it seems like two months
Old Dec 6, 2009 | 04:33 PM
vthokieharley
Thanks for the help guys. It was the rear tire that cut the left turn signal wire, and had almost cut the right turn signal. Fixed them both, and fabbed up some tabs to keep the wires from getting to the tire again.
Thanks again yall.
Northbound Southerner
Oct 8, 2013 11:28 AM
packrat56
Sep 27, 2010 08:28 AM
road bling
Aug 2, 2008 08:41 AM
hawg68
Jun 18, 2007 01:23 PM
toddsheritage
Jun 23, 2005 10:23 PM
