Need a Little Help :)
Old Dec 14, 2009 | 07:06 PM
06BlackBob's Avatar
06BlackBob
Default Need a Little Help :)
So I've got my stuff gettin powdercoated right now, and I wanted to drill out my new apes for internal wiring. It already has the dimples for the grips, but how big of a hole do I need to make for the wiring in the dimples AND at the bottom of the bars (by the risers)? Thanks
Old Dec 14, 2009 | 08:47 PM
sporty79's Avatar
sporty79
You want at least a 7/16" hole at the controls. 1/2" would make it a bit easier. I've tried both and they will each work. In the center you want a 1" slot (use the same diameter hole as the ends).
Make sure you file down the holes real smooth. Run a piece of tissue paper around the rim to check for snags.
Ashnic
Milwaukee Eight (M8)
13
Jun 11, 2024 09:40 AM
tnriverluver
Mar 23, 2016 03:22 PM
sexpanther
Feb 23, 2012 09:44 PM
thone
Sep 23, 2010 04:34 PM
Wobbie1775
Mar 15, 2008 05:16 PM
