Engine rebuild suggestions
Old Dec 15, 2009 | 02:33 PM
JDixon's Avatar
JDixon
Default Engine rebuild suggestions
Hello all,
I'm looking to replace/rebuild my 1998 evo top end. ie: pistons, cylinder head replacement or rebuild for more power from the stock evo displacement.
It's got 70k+ and is getting slow. I'm looking for more accelaration from the 0 to 85 mph range. Any kits or companies to recommend? I don't want to bore the caes but an oversized cylinder bore would be ok.
I haven't talked to a small indy shop (one guy) I plan to use about it yet...would like more opinions.
Old Dec 15, 2009 | 02:46 PM
REVL33's Avatar
REVL33
Originally Posted by JDixon
Hello all,
i would rebuild the whole thing while your at it , someone can correct me if i am wrong but doing the top end only might give you problems on the bottom end .
Old Dec 15, 2009 | 03:07 PM
Lama's Avatar
Lama
1) Rebuild the entire engine at 70k miles. Replace only whats worn, and then install a nice camshaft, new oil pump, breather gear, etc.
2) Then, convert the top-end to a Twin Cam...also called a Fatso.
http://daytonabeachcycles.com/Fatso-Information.html
Old Dec 15, 2009 | 03:18 PM
JDixon's Avatar
JDixon
Hate the Fatso look.. I'm a die hard Evo guy. The other suggestions I'll consider especially lifters and oil pump etc. I just wanted to avoid pulling the cases apart if at all possible.
Old Dec 15, 2009 | 03:57 PM
grbrown's Avatar
grbrown
As Revl33 suggested, if you rebuild the top end you will probably blow the bottom end shortly after. A few years ago a friend of mine did just that.
You can bore the cases out a little to get a bigger cylinder in, alternatively you can stroke it, as I did, to 89". You may find you can both bore and stroke it.
But you would be far better off talking to a tuning shop for recommendations, such as some of the HDF sponsors. These guys can work wonders with motors these days and probably offer you more improved performance than you thought possible.
Old Dec 15, 2009 | 07:53 PM
Phrogman's Avatar
Phrogman
You can rebuild the top end with no problems. I put .010" over Keith Black 8.5:1 pistons in my 88 FXR and had no problems whatsoever from the motor. Port and polish the heads, put in an EV27 or EV3 cam and adjustable pushrods, Mikuni HSR42 with a K&N filter. You'll be happy.
Oh yeah, don't forget to convert to a single-fire ignition and coil.
The only drawback I had was an occasional hard start. I'd have to back off the starter to let the motor release compression and then hit it again sometimes. You could probably avoid that with compression releases or a more powerful starter, but mine is still working for my Brother-in-Law to whom I sold the FXR.
Old Dec 16, 2009 | 03:05 AM
REVL33's Avatar
REVL33
so how many miles did you have on it when you did that he has 70,000 and talking about a whole top end which is entirely different,
Old Dec 16, 2009 | 11:42 AM
JDixon's Avatar
JDixon
OK, I got it. I'll go with the whole thing... now, any New Englanders out there to give recommendations of indy shops in Pref. ME/NH? I had one guy in mind but maybe I should talk to other shops about a full rebuild.
Thanks all.
Old Dec 16, 2009 | 01:17 PM
gibbyflhx's Avatar
gibbyflhx
I would strongly recommend R&R cycles in Manchester NH, you will get an amazing build for sure and they are one of the best around.
Old Dec 17, 2009 | 02:08 PM
JDixon's Avatar
JDixon
I've heard of them. I'll give'em a call. Thanks
