ignition timming help
Old Dec 17, 2009 | 09:20 PM
gtojets's Avatar
gtojets
Default ignition timming help
I bought a used 94 dyna convert. EVO. after reading on this forum about the INA cam bearing failure I decided to pull the cam and change out the bearing. while doing this I notice that the ignition module was upgraded to a dyna 2000 HD1. I downloaded the instructions from dynatech websight. in the instructions was told to stactic time the module by finding tdc on compression stroke. ( pull plug put line on flywheel in middle of plug hole) and turning sensor plate clockwise till led light turns off. the problem is that the sensor plate will not rotate far enough to turn light off on the module with lock down bolts install. the sensor was in the up position when I took off. I believe i can make this work if i rotate the sensor to the bottom side. Is this the way the cam sensor should have been install? any ideal or help would be appricated
Andy2166
Jun 15, 2018 06:38 AM
lady's mum
Jun 19, 2017 07:06 AM
straightleg
Jan 19, 2015 09:18 PM
gtojets
EVO
Dec 21, 2009 08:16 AM
toolbox
Custom Models
Sep 29, 2006 12:17 AM
