1992 super glide
Old Dec 21, 2009 | 03:38 PM
boberhel's Avatar
boberhel
Stage II
Default 1992 super glide
i let the bike sit for a year and now after running it , it is allowing oil to come out thru the crankcase brreather and it runs out over the engine thru the air filter. i pulled the check valve out and it was clean and shiney so what else could it be? there seems to be alot of pressure coming out of the breather pipe but no oil till it gets fully warmed up. thank you
Old Dec 21, 2009 | 03:56 PM
rounder's Avatar
rounder
there is the possibility of the oil being overfilled? I don't know anything about evo's that tends to be the cause for many onf the twin cams oil through the breather problems. I get oil out of my breathers when hot, not too much sometimes it does get a few drops outside the air cleaner. Is it just flowing out or just getting a little bit?
Old Dec 21, 2009 | 04:09 PM
fixxr's Avatar
fixxr
You may need to replace the spring under the check valve ball. they may look OK but they do get weak after awhile.Have you ever changed the spring?
Old Dec 21, 2009 | 04:46 PM
boberhel's Avatar
boberhel
Stage II
down now to little spray at very fast idle. oil level is a little low. never thought of spring being bad
strych9
Engine Mechanical Topics
Aug 1, 2020 03:10 PM
TheKingKP
Aug 10, 2018 01:26 PM
jeffsizemore
Mar 24, 2017 11:37 AM
Bassin
EVO
27
Jun 12, 2014 04:28 AM
hdbeggs
Feb 6, 2011 07:48 PM
