Handling
Old Feb 14, 2010 | 06:01 AM
toaster's Avatar
toaster
Stage IV
Engine Mont are new installed 3000 KM ago
Not Bike Developed this problems about 15,000 ago
Old Feb 14, 2010 | 10:34 AM
MidnitEvil's Avatar
MidnitEvil
Started 15,000 km ago, sounds like you've replaced or check pretty much everything ,only happens between 60-80 kph and it tracks fine when you let go of the bars.
Bar weights do reduce vibration in the bars, but they are not the answer for you as something is obviously wrong. You don't want to mask the problem - you have to fix it.
I also have an '02 WG and do not experience anything like what you are experiencing. The fact that your bike didn't always do it indicates a problem as well.
Was there something you changed 15,000 km ago?
I think you need to start from the beginning and check everything again, starting with the basics. Check that your spokes are tight, the wheel is true and balanced. We can probably rule out the tire since you recently replaced it, but definitely look it over for defects anyway. Check your fall away. From there you have to get into checking everything on the front end - maybe even something like different levels of fork oil in each fork or something.
Old Feb 14, 2010 | 11:23 AM
grbrown's Avatar
grbrown
As well as all the other suggestions I have two thoughts. One, which I suffered from with my FX1200 all those years ago, was simply holding the bars too tight. Tension in your arms and wind buffeting can cause what you describe. The other is that all Dynas will benefit from a TrueTrack stabiliser kit. They prevent sideways movement of the engine rubber mounts and tighten ride and handling a treat. I have them on both my Dyna and Glide.
Reece64
Aug 2, 2014 07:59 PM
Sliver1
Jan 1, 2014 11:47 AM
slipvayne9278
Jul 9, 2011 10:56 PM
MOTOKILLER
Feb 14, 2011 12:10 PM
vetto
Wheels/Tires
Jan 30, 2009 07:29 PM
