help - Smart Siren II
Old Jul 17, 2006 | 09:50 PM
subculture08's Avatar
subculture08
Default help - Smart Siren II
Trying to install Smart Siren II on 06 Bob.
The instruction say locate the conector wire behind the elec cady taped to the frame.
I can not find the damn thing! [:@]
Any help would be great.
Old Jul 17, 2006 | 09:56 PM
WgSkee's Avatar
WgSkee
Default RE: help - Smart Siren II
TCSTD posted this... do a search on Smart Siren II he has pic's there as well
arley-DavidsonÂŽ Factory Security System
Here's two links that will show you a typical installation... HERE and HERE
The only security system designed and approved by the Harley-Davidson Motor Company. When armed, the Security System disables the starter and ignition while monitoring the electrical system and vehicle motion with adjustable sensitivity. Minor disturbances trigger a momentary warning; major ones an unbroken thirty-second alarm after which the Security System returns to monitoring. A distinctive four-way flasher pattern is the alarm signal. An optional self-powered Smart Siren Kit adds a piercing scream, which sounds even if the battery cable is cut. Harley-Davidson Factory Security System includes Security Module (integrated security, turn signal and bank angle sensor), Remote Control Waterproof Key Fob and Pocket-Sized Operation Manual. An Extended Storage Mode keeps the battery from discharging when the Security System is armed for extended periods of time. 2000 model year vehicles require installation kits (sold separately).
HARLEY-DAVIDSONÂŽ FACTORY SECURITY SYSTEM DETAILS
The Security System is armed and disarmed with a remote control waterproof key fob utilizing state-of-the-art rolling code technology. If the key fob is not available, the rider may disarm the system by keying a previously entered personal code on the turn signal switches. A flashing status indicator informs the rider that the Security System is armed or disarmed.
When armed in the Transport Mode, the Security System disables the starter and ignition, but monitors only the electrical system, not vehicle motion. The vehicle may be moved, but electrical tampering triggers an alarm.
The Security System is compatible with FL Touring models equipped with approved TLE/Ultra Sidecars when the system is configured as described in the SIDECAR OWNER'S MANUAL.
Additional Smart Siren
Harley-DavidsonÂŽ Factory Security System Smart Siren Kit
Add an additional level of security with this battery-operated siren. The replaceable internal battery provides continued security if main battery is disconnected. This high-powered siren has a piercing sound, and has built-in plug-type connector for easy connection to the wiring harness. Kit contains Smart Siren, mounting bracket and additional brackets and mounting hardware.
A Quick Install run down...
The cables are plug and play and keyed so you really have to work at it to mess it up.
1. Remove seat and disconnect battery ground.
2. Remove TSM module and replace with TSSM module (under seat aft of battery)
3. (Optional) Remove right side ECM cover and install Smart Siren II behind ECM mounting bracket
4. Reconnect battery
5. Program unit per supplied instructions
6. Follow "password learn" procedure from DIY section here HD Electrical Diag Manual. (takes 30 minutes)
7. Follow "clearing error code" from DIY section here or HD Electrical Diag Manual
Alternative pay dealer to run Diagnostic Technician software to marry new TSSM to ECM and clear error codes.
Source: HD Homepage
Old Jul 17, 2006 | 10:00 PM
WgSkee's Avatar
WgSkee
subculture08... hE ALSO HAS SITES HIGHLIGHTED THAT SHOW THE INSTALL... gOOD lUCK......d&%M cAP bUTTON...gEEEEZZZ
Old Jul 17, 2006 | 10:03 PM
subculture08
Thanx - just read them over...
But they just show the guy plugin in the DAMN wire that I cant find [:@]
Old Jul 17, 2006 | 10:08 PM
WgSkee's Avatar
WgSkee
D$#m.... They make this stuff easy... I'm thinking of getting one myself.... I put a disk Lock on.. but, ya can't have enought security...
Your looking for the turn signal modual right??? I'll go check mine now...
Old Jul 17, 2006 | 10:18 PM
WgSkee's Avatar
WgSkee
Sorry... My service manual is at my inlaws... I was going to see if it had anything that would help... Anybody got their's available?
Old Jul 17, 2006 | 10:25 PM
Soda's Avatar
Soda
I had the same problem, and when I did find it, it sure as hell wasnt taped to the frame. Theres a whole buncha plugs back there, I just dug around till I found the one that matched the one in the siren installation instruction picture...
Old Jul 18, 2006 | 12:17 AM
subculture08
Thanx I found it - Soda is right - it is NOT taped to the frame,
And now as if this simple install was not bad enough... the siren will not fit into the "back of the caddy" as indicated.
The cut out seems to be just wide enough to go in the short way - but then it hits the frame.
KILL ME![:@]
Old Jul 18, 2006 | 12:28 AM
subculture08
I think I have it - The pic. is incorect for the 06.
I will post info IF everthing else goes ok
Old Jul 18, 2006 | 12:57 AM
WgSkee's Avatar
WgSkee
Please Do... Let us know.. How it works, and if it's worth the $$$...
