Okay I've searched this forum for 2 days trying to find a post. Someone did a cheap mod (& yes I looked through all 138 pages of the "under $50" mods) on the front-end. They lowered the front by cutting down the oem spacer that fits above the spring on the front forks or cut the oem springs..or something. Progressive drop-ins have the same principal, different size pvc spacers...but I'm looking for a more economical way of doing it.
On my 2010 there is no room to run the forks up into the trees, I attached a pic. They are already almost touching my handlebars.
Does anyone remember this thread or have any new ideas? Thanks.
i think by cutting those spacers, you would reduce the preload on the springs but not lower the front end. you just end up with a mushy front end which would have a tendancy to bottom out. just my 2 cents for what its worth.
By cutting (shortening) the spacers you will decrease preload (spring tension) and increase sag. It will set your bike lower, but you may bottom out the front more since you are not putting in stiffer springs. Cut off a little at a time. Measure how much the front drops with each cut and ride the bike. A 1/2in cut will probably not give a 1/2in drop because of spring tension.
I had a friend that cut the stock spacers and destroyed the ride...i wouldnt do it.The drop ins are only 130.00.Wait and do it right.I used the progressives drop ins and love them.....
These guys are right on the money. Do not shorten the spacer or you will bottom out on a rough bump and possibly get the handlebars knocked out of your hands when it happens.
+1
Like dpriest says the spacers are there to set preload. Shortening the suspension will make the bike lower but at the cost of making it handle like crap. 1) less suspension travel means less controlled and confidence inspiring ride over bumps and irregularities in the road surface. 2) Lower ride hight means you will be dragging hard parts in turns much sooner, possibly at just above legal speeds - which would mean you have no handling safety margin.
Just a suggeston but try sculpting the foam in the seat first to make it narrower or shallower as a first alternative. This will allow you to get your legs closer to the bike at a stop. Also you do not need to be able to flat foot a bike to ride it safely, just as long as you can get the ***** of your feet on the ground.
i agree that its possible you might scrape more...but i lowered my sb 2" in the front and 1" in the rear and the ride and handling is much better then when it was stock...i also ride 2 up alot with my wife and never bottomed...the front of my bike had a mushy feel stock and after i lowered it i love it....just mt 2 cents.....
