bikefire
Old Jan 2, 2010 | 12:34 PM
archergodwin's Avatar
archergodwin
Originally Posted by 08fxdf43202
It's still under warranty.... take it in and let the dealer deal with it.
X2... right there.
Old Jan 2, 2010 | 12:58 PM
zombiesawyer's Avatar
zombiesawyer
i wanted to check the threads before taking it to the dealership. the dealership service department around here is horrible. i can almost guarantee that they will tell me nothing is wrong and charge me a fee for looking at it. thats what they did when i had an issue with the rear turnsignal/brake light. it would keep burning out and they said that the bulb was just bad but i told them that it was the 3rd bulb this month and that there had to be a wiring problem. they said they could not find anything and charged me for the bulb and .1 hrs labor. i haven't been back since.
Old Jan 3, 2010 | 08:22 AM
HarleypsychRN's Avatar
HarleypsychRN
I had a grinding noise about a year after I had my bike. New starter soon afterwards.
Old Jan 3, 2010 | 08:26 AM
lionsm13's Avatar
lionsm13
So did your bike burn up then with the "bike fire"?
Old Jan 3, 2010 | 08:29 AM
Taddeoeg's Avatar
Taddeoeg
The backfire is likely no big deal as has been stated but the starter grinding could be. If you don't like Modesto why not take it to a different dealer? Yeah I know - distance, inconvenience, yada, yada, yada. But you'll hate yourself if the warranty expires and you end up paying big bucks for a bunch of parts that got trashed due to a misaligned gear.
Call ahead for an appointment and tell the you plan to wait. A decent dealership will bust butt to honor your appt time and make sure the tech stays focused on the task to minimize your wait.
Old Jan 3, 2010 | 09:18 AM
2003FXDX's Avatar
2003FXDX
I'd take it to a different dealer if you're not happy, but if it's under warranty let the dealer fix it.
Old Jan 3, 2010 | 11:52 AM
LilBitPsycho's Avatar
LilBitPsycho
Me thinks you have an intake leak.
Old Jan 3, 2010 | 11:54 AM
Nightking's Avatar
Nightking
Originally Posted by Nick0915
is that bike efi or carbed? Either way, check the exhaust for leaks or a loose bolt.
All the 07 -up are EFI.
Old Jan 3, 2010 | 01:30 PM
bigmikaele's Avatar
bigmikaele
your bike doesn't sound like it has had any extensive engine work, but mine had some blow back issues during hot starts and when it started it wasn't all the time, but over time got worse. I put a 103" in mine and had added a bit more cam this resulted in some compression issues on a hot start and so I am currently having compression release valves put in... I know that over time with these blow backs it has a tendency to destroy starters. For me the gasket on the front cylinder head cover failed and started to seep oil... it should be fixed this week. Just some food for thought, but not thinking your problem is quite the same as mine, probably as others have said a mis-tune, but should be brought back and fixed before you need a new starter.
Old Jan 3, 2010 | 01:39 PM
jimsflh's Avatar
jimsflh
I'd check BOTH ends of BOTH battery cables first (although I suspect the positive if that's the problem), then exhaust and intake leaks. I didn't see if you said carb or EFI, if it's carb, and you have a tuneable ignition, have you been playimg with the timing?
