Night train rear wheel?
Old Jan 2, 2010 | 10:22 PM
jstreet0204's Avatar
jstreet0204
Default Night train rear wheel?
Will a 2006 night train rear wheel fit on a 2008 street bob, or is it too wide. I know they came stock with a 200 rear tire, but I can't find anything on the actual wheel widths.
Old Jan 3, 2010 | 01:31 PM
jstreet0204
Just want to bump this. There is one for sale locally pretty cheap.
Old Jan 3, 2010 | 01:50 PM
bowman78's Avatar
bowman78
Default i bet it would
bearing size will be the problem though.... you'll probably have to change bearings im sure.... i put a duece rim on my 04 dyna with no problem... also it has a 160 tire on it and i could probably get a 170 on and still clear the belt and fender and i know the 06 and up bikes have wider components in the rear.......................tim
Old Jan 3, 2010 | 01:57 PM
JaronB's Avatar
JaronB
This should answer your question or one of them should be able too!!
https://www.hdforums.com/forum/dyna-...an-05-now.html
Old Jan 3, 2010 | 06:01 PM
U-234's Avatar
U-234
On eBay I've seen two Night Train wheels stated as being 6 inches wide. Axle will be 3/4 inch. I have a 2008 6.5in Fat Boy wheel and stock 200 Dunlop on the back of my '07 Street Bob. It took some machine work, widen the struts, change bearings and a wider fender.
More pics are in my Album.
Attached Thumbnails Night train rear wheel?-283.jpg   Night train rear wheel?-100_0717.jpg
Old Jan 4, 2010 | 12:58 PM
rounder's Avatar
rounder
won't just bolt right up, I think it is a 6.5" rim.
Old Jun 22, 2010 | 03:07 PM
jcallesano's Avatar
jcallesano
try this:http://www.hdwheels.com/images/Order...nt%20Table.pdf
Old Jun 22, 2010 | 03:55 PM
JRK5892's Avatar
JRK5892
i think that jackle put that on his bike if i am not mistaken... not sure though
Old Apr 7, 2016 | 08:39 PM
Fxdcmatty's Avatar
Fxdcmatty
Stage II
Did you have to use a wider swing arm or will the stock 1 work??
Jsdrillin
Feb 19, 2018 09:27 PM
Cmcbay
Mar 23, 2017 12:10 PM
moomba
Softail Parts
Sep 4, 2014 11:38 AM
Eight Songs
May 15, 2012 08:10 PM
cbaker
Jun 20, 2008 10:29 AM
