Thumping Dyna
Old Jan 8, 2010 | 06:51 PM
rdondes's Avatar
rdondes
Vance & Hines Straightshot Slip-On mufflers with Big City Thunder (BCT) Monster Baffles. This is as close to the old sound as you'll get without bigger cams.
Old Jan 8, 2010 | 07:02 PM
J-RoX's Avatar
J-RoX
Toss the Fuel injector - get a carb and tune it low.
but beware the lower idle will inhibit lubrication.
i thought about doing it to my bob.
other than that buy an old one and re build it. nothing better than riding something that every bolt was torqued down by your own hands. .
Old Jan 8, 2010 | 09:44 PM
r00k's Avatar
r00k
There are tuners that let you drop the idle speed, but the twin cams need the higher idle to keep up the oil pressure...
It'd be a boring way to break a nice motor.
Old Jan 9, 2010 | 10:06 PM
motorcyclelockman's Avatar
motorcyclelockman
Thanks Guys. Good info. I knew you would not let me down.
Old Jan 10, 2010 | 02:23 AM
Rebel78's Avatar
Rebel78
I got V&H slip ons for my 07 Bob, if I had to do it again I'd go for Cycle Shacks, best sound ever.
Old Jan 10, 2010 | 03:07 AM
performanceisthekey's Avatar
performanceisthekey
Uh there is no such thing as "an old school carburetor sound" carburetors have nothing to do with the sound of combustion and crank firing.
Old Jan 10, 2010 | 05:53 AM
domenicp7's Avatar
domenicp7
V&H BSS I do have a 103 though.
Old Jan 10, 2010 | 06:19 AM
kylejwink's Avatar
kylejwink
6th Gear
Originally Posted by r00k
Chasing down the carbed sound on the twin cams is an expensive endeavor.
He'll probably need Pipes, Intake, Cams, and a tuner...
Really, just have him ride the stock pipes for a little bit and listen around for what he likes on other bikes.
X2...I have the Big City Thunder baffles in the older style SE slip ons, sounds decent, but you'll never get that lopey carbed sound. Pretty much anything is better than stock though...IMHO I'd go with the Cycle Shack slip ons till you can afford to do full exhaust and a stage 1. Its all in taste and budget though, everyone will tell you something different.
Old Jan 11, 2010 | 08:02 PM
motorcyclelockman
Man, this place is a wealth of knowledge. I never thought I would get this much response. Thanks guys!
Old Jan 11, 2010 | 08:30 PM
ackman1968's Avatar
ackman1968
Have you ever listened to a carbed Twin Cam next to an injected one? There is a difference in how they sound and that's why everyone refers to it as the "carbed sound". Is it all in the carb? Not entirely but it does come into play. Biggest reason for the difference is the cam, there's less overlap in the new bikes to make the EPA ***** happy. Even with the same cams a carbed bike should have more lope because ir relies on the vacuum signal to meter the fuel where the injection relies on the ECU.
