grip troubles
Old Jan 8, 2010 | 09:28 PM
cerelious's Avatar
cerelious
Default grip troubles
Hello. New to the forum. I tried ti install the ISO grips today. We put the right side on tested it out. It pulls the valve open, put it doesn't spring back like it ought to.
We double checked to make sure the cables are in the right position, but it still stays open unless you twist it back. any suggestions? Thanks for the help. Hope my situation is clear.
Cerelious
Old Jan 8, 2010 | 09:45 PM
Wonkaboy's Avatar
Wonkaboy
Check your manual cruise control **** located under the throttle grip make sure it's backed off ...
Old Jan 8, 2010 | 10:24 PM
ghostrider69's Avatar
ghostrider69
My ISO grip is slow about returning to idle unless you give it a little help. I have tried everything and still can't figure out why it's like that.
Old Jan 8, 2010 | 10:25 PM
Phrogman's Avatar
Phrogman
You have two cables, the throttle and the idle. The idle cable is the one that returns your throttle to the resting position. There should be a spring on the end of the idle cable which attaches to your vavle on the throttle body.
If you haven't already, pull your air cleaner and backplate so you can get a clear view of your throttle valve. Manually move it through full rotation so you can see it hit both the idle stop and the wide open stop. Adjust your cables until you can hit both stops and the throttle springs back to idle.
Old Jan 9, 2010 | 12:20 AM
cerelious's Avatar
cerelious
Default throttle
hello all. having issues with my new grips. installed the throttle side, and when i twist the grip, its sticks instead of springing back. checked to makes sure that it was done right. any suggestions? thanks for the help
cerelious
Old Jan 9, 2010 | 12:41 AM
seadblyou's Avatar
seadblyou
6th Gear
cerelious
It sounds like end of the sleeve is catching. Disconnect the ferrules and cables and twist to see if it spins freely.
Old Jan 9, 2010 | 01:39 AM
jmpancoast's Avatar
jmpancoast
Not knowing what you did, we need more info.
Did you properly adjust the cables?
Did you apply lube on the bar, under the throttle barrel?
Any chance the end of the bar is in contact with the inner end of the new grip?
Old Jan 9, 2010 | 01:51 AM
cerelious's Avatar
cerelious
didnt know i had to grease it. and not sure if it is touching the end of the bars. they are new bars. i will look into both. what kind of grease should i use? thanks for the help.
cerelious
Old Jan 9, 2010 | 05:13 AM
Bob'n'Stang's Avatar
Bob'n'Stang
The grip is probably dragging on the handlebars or the switch housing. I had the same problem when I changed mine. My problem ended up being the switch housing. There is a groove that the throttle sleeve fits in and it seems that on the new models that groove is so far away from the outside of the housing that alot of aftermarket grips bind up because of the lack of clearance.
I ended up having to take a dremel tool to my grips and make some clearance but I haven't had a problem since. I hope this helps good luck.
Old Jan 9, 2010 | 07:25 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
.........We double checked to make sure the cables are in the right position, but it still stays open unless you twist it back. any suggestions?....
Here's a link to the MULTI-FIT BRAIDED THROTTLE/IDLE CABLE KITS instructions sheet. Check the step by step instructions and the diagrams. I hope this will help you to solve your problem.
FXD2003Rider
