Forwards
49080-03A 1993 to 2005 models
1 Shifter rod 11739B
2 Washer, 5/16 x 11/16 x 1/16 6702
3 Locknut 7710W
4 Shifter lever 33789-03
5 Acorn nut 7736
6 Spring washer 34625-90
7 Shifter bracket 33695-03
8 Hole plug (4) 740
9 Shifter shaft cover 34640-93
10 Primary shift lever retainer bracket (2001 and later models) 34639-01
11 Torx® screw, 3/8-16 x 1 (4) 4059
12 Shaft cover set screw 3231B
13 Primary shift lever retainer bracket (1993-2000 models; see note below) 34639-93
14 Hex head screw, 5/16-18 x 5/8 2882W
Items mentioned in text, but not included in kit:
A Transmission shift lever
B Primary shift lever
C Shifter lever
Notes:
D Shown positioned for models 1993-1998 Evolution engines.
E Shown positioned for models 1999-2000 Twin Cam 88 engines.
15 Brake pedal pad 42532-82
16 Brake pedal 42542-03
17 Locknut, 1/4-20 7742
18 Brake pedal bracket 33697-03
19 Brake pedal pivot shaft 42665-03
20 Cotter pin 515
21 Footpeg mount clevis 42664-03
22 Washer, 1/4 x 7/16 x 1/16 6099
23 Torx® screw, 3/8-16 x 2-3/4 4339
24 Clevis pin 42460-80B
25 Brake rod 41955-03A
26 Jamnut, 5/16-24 7744
49021-09 2006 and later models gloss black
1 Shifter rod, black 33737-09
2 Washer, 5/16 x 11/16 x 1/16 inch 6702
3 Acorn nut, black, 5/16-18 locknut 8196
4 Shifter shaft and lever, black 33733-09
5 Spring washer 34625-90
6 Transmission shifter lever, black 33735-09
7 Shifter bracket, black 33649-09
8 Hole plug (4) 740
9 Primary hole plug, black 6943
Primary hole plug, chrome 90357-89
10 TORX screw, 3/16-18 x 1.0 inch (4) 4059
11 Sealing fasteners (5) 5-786A
12 Foot shift lever, black 34501-09
13 Brake pedal pad 42532-06 19 Washer, 1/4 x 7/16 x 1/16 inch 6099
14 Brake pedal, black 42556-09 20 TORX screw, 3/8-16 x 2-3/4 inch 4339A
15 Brake pedal bracket, black 33682-09 21 Clevis pin 42460-80B
16 Brake pedal pivot shaft 42665-03 22 Brake rod 41955-03A
17 Cotter circle 51938-04 23 Jamnut, 5/16-24 7744
18 Footrest mount clevis, black 42703-09
chrome 2006 and later
1 Shifter rod 34887-06
3 Acorn nut, 5/16-18 locknut 7736
4 Shifter shaft and lever (new) 33789-06
6 Transmission shifter lever 33883-06
8 Hole plug (4) 740
9 Primary hole plug 90357-89
10 Torx screw, 3/16-18 x 1.0 inch (4) 4059
15 Brake pedal pad 42532-82 21 Footrest mount clevis 42664-03
16 Brake pedal 42542-03 22 Washer, 1/4 x 7/16 x 1/16 inch 6099
17 Locknut, 1/4-20 7742 23 Torx screw, 3/8-16 x 2-3/4 inch 4339A
18 Brake pedal bracket 33697-03A 24 Clevis pin 42460-80B
19 Brake pedal pivot shaft 42665-03 25 Brake rod 41955-03A
20 Cotter pin 515 26 Jamnut, 5/16-24 7744
But the not sure how much difference there is but looks like i wouldn't chance it unless you knew for sure they would work.
Put it on and find out if you have it.
