inner primary?
Old Jan 16, 2010 | 02:07 PM
wild one's Avatar
wild one
Thanks for everyones help. When i bought this on ebay they said it was a 60794-06B. When i received it was 60794-06 was hoping i could take the dowels out of my primary & put in the new one.
Thanks again
Old Jan 16, 2010 | 02:15 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Thanks again
You could ask the seller to have it replaced by the "B" version. If he/she's non co-operative, use the Ebay Buyers protection program and open a case in the "Resolution Center"
FXD2003Rider
Old Jan 19, 2010 | 01:46 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I believe Ronn R is right. These are from my friend Andreas, who owns a dealership in Spain. If memory serves, the -06 is the standard '06 inner case. The -06A is used on '07+ and has alignment dowels for IP to Tranny Case. If you're doweled, you don't want to waste your Flux Capacitor stepping back in time to the days of IPB problems, caused by lack of alignment dowels.
Old Jan 19, 2010 | 09:46 AM
ehc0720's Avatar
ehc0720
I have an 06 WG with a build date of 03/06. Is there any way to tell if I have the cases with the dowels or not without opening them up? I've read that they started using the dowels again half way thru the 06 build year.
Old Jan 21, 2010 | 02:59 AM
PKellyMc's Avatar
PKellyMc
I'm not certain, but I think the cast-in p/n is on the tranny side of the IPCase. Might scout out some ebay IPCases for some close-up pix to confirm or disprove this. If it's on the OPCase side (depending on locale), you might be able to see the p/n by "just" removing the outer case. Hopefully it's not located behind the clutch or other innards.
SpiderPig
Sep 12, 2015 09:31 AM
SpiderPig
Stock Harley Take Offs
Sep 12, 2015 09:30 AM
P'colaHarley-17RGS
Oil Archive (no new posts)
Dec 11, 2013 08:46 AM
Nisbet
Jul 17, 2010 08:20 PM
jimnc
EVO
Jul 5, 2008 12:57 PM
