05 superglide electrical draw/short
I have an electrical draw/short that will drain the batt. pretty quick.
I have isolated it to the circuit labled battery in the fuse block, according to the wire diagram this powers the speedo and the turn signal module. If I disconnect both of these from the harness the short goes away. If I plug either of these in, the speedo or the signal module the short returns.
Im not thinking both of these are bad so that leaves somthing else that is common to them both. this is where my diagnostic skills end.
Can anyone advise what to look at next.
Thank You
Tom
Last edited by Shovelhead Bob; Jan 24, 2010 at 08:21 PM. Reason: Duplicate Postings in multiple forums
