my dyna is breathing better but??????
Old Jan 27, 2010 | 07:10 PM
pirate87saw's Avatar
pirate87saw
Stage III
Default my dyna is breathing better but??????
Hey guys, I have a 92 dyna with a well broken in 1340 evo. Its got 38,000 on it. I just installed a set of rinestars, flush tips, and put on a forcewinder intake. I have had mixed opinions on whether or not I need to re jet. I talked to a couple of friends and they said to go one up on both jets. Harley said they would love to look at it and figure it out, thanks guys, hard to find a tech who just wants to help for free. It runs pretty good, just noticeably different. Its an older engine and she seems hesitant to accept change. It has a stock cv carb on it. It backfires a bit more, slow accelerating from start, but smooth once up to speed. I am just wondering if anyone else had this setup and what they did, or what the guru's recommend. As far as top end its good, thats why I am asking? Should I go one up on both, also begs the question of what octane fuel I should be running. Any answers or insight is greatly appreciated.
Old Jan 27, 2010 | 08:23 PM
dope_man_21's Avatar
dope_man_21
The only way to really tell without dynoing the engine or monitoring the air fuel mixture while running the engine is to learn to read the sparkplugs. I included a couple of links to give you a heads up on it. When we were racing dirt track cars this was the key between winning and building another engine.
http://www.dansmc.com/spark_plugs/sp...s_catalog.html
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
wescoot2's Avatar
wescoot2
Sometimes the old ways are the best. Put a fresh set of plugs in your scoot and put a couple of hundred miles on them. Pull them and take a look. If you see that your scoot is now running lean or rich, as the plugs will indicate, adjust your jets accordingly.
Old Jan 27, 2010 | 09:03 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would get a mikuni carb and maybe a new intake as well.
Old Jan 28, 2010 | 08:43 AM
Phrogman's Avatar
Phrogman
Man, 38,000 on an EVO is just starting to break it in! The Mikuni idea is good, but the best bet for least amount of money is to do as suggested and tune based on plugs. That will get you in the ball park. Beyond that, you'll have to take it to a dyno and a good tuner.
Here is a pretty good guide on tuning a CV carb: http://www.harley-performance.com/ha...arburetor.html
monchidog
Carburetor Related
14
Dec 12, 2016 04:20 PM
arkmark
EVO
Sep 30, 2014 06:30 PM
arkmark
Sep 27, 2014 09:24 AM
2006ultra
EVO
Jun 13, 2014 04:03 PM
maryland blackout
Sep 14, 2011 03:22 PM
