cam gear question
Old Jan 30, 2010 | 01:58 AM
cexodusk's Avatar
cexodusk
Default cam gear question
2008 Street Bob Specs:
103 Big Bore kit
SE Air Cleaner
Woods tw-408-44 cam
Woods +4 Degree Cam Gear
V&H Short Shots
Power Commander 5 w/ o2 sensor elim
Question is, I am wanting to put on a set of stock heads with a port job, stainless valves and compression releases.
What are the pro's and cons of having the +4 cam gear in? Do I need to take this out?
Old Jan 30, 2010 | 10:38 AM
SC-Longhair's Avatar
SC-Longhair
yes, do the heads and remove the +4 gear. In fact, if you remove it soon, I'll take the +4 gear off your hands.
Old Jan 30, 2010 | 03:20 PM
U-234's Avatar
U-234
You didn't state what Woods cam you are going with. It depends on the cam if the +4 will work better with your build. Talk to Woods.
Old Jan 30, 2010 | 03:21 PM
cexodusk's Avatar
cexodusk
all the listed are already in the bike, and its a woods tw-408-44 cam.
TW-408-44
24/44
46/22
248
248
.530
.530
.213
.199
Stock
Hot Rod 07-09 Bolt-In - Stock Heads, Springs,
Stock thru 11:1 C/R
Old Jan 30, 2010 | 03:26 PM
SC-Longhair
If he does the heads which would probably include milling the deck for slightly higher compression, keeping the +4 gear in there could cause clearance issues between the valves and the top of the piston. You may want to rethink your advice or at least offer to flip half the bill if he toasts his motor.
TwiggyAZ
Southwest
Nov 24, 2009 08:31 AM
Casper
Dec 31, 2008 08:50 PM
