foot ball
of stock foot ball style cleaner covers?
I purchased the scull insert that goes in the middle of the stock cover.
To me it looks like the middle part that has the bolt hole does not
come out.
The scull insert is the one where you use the stock cleaner bolt
to attach a star like piece that has 5 attach points.
It's the one in the 2006 catalog multi fit pg562 #29417-04
Thanks
I think this is what you're talking about right?
Todd
So what you are saying is that there are two different aircleaner covers.
One with the 1 bolt system and one with the five.
I have the one bolt.
So I guess that means I can't use the scull insert because it has the
five bolt pattern right?
How do you take apart the center section of the stock cover?
I can't see how it comes apart.
I have the directions that came with the scull insert.
It tells you to remove the circular piece, the part that says
dyna wide glide on it. But there aren't any holes under it to put
the five fasteners through it and into the star plate that is now
attached to the bike with the single stock bolt.
I'm either a dumb *** or I just don't no how to articulate this
question.
Thanks
I still am confused.
question.
Thanks
And yes...you need to remove that to install any upgraded air cleaner insert. So..yeah..remove the piece that says "Dyna Wide Glide"....how to do it...hard to say. I just pryed mine off with a screwdriver. If you're not interested in keeping it, that'll work fine..just be careful not to scratch the actual "football".
Does this answer your question?
If not, I could post some pics of the football cover without that "circular" piece. Once your football cover has that removed, you can pretty much install any air cleaner insert...whether it's the 1 (stock) bolt setup...or the air cleaner insert + five bolt plate setup.
Hope this doesn't confuse you more.
Todd
I don't really want to remove it if there arn't the five holes under it.
Thanks
Now I get it, I thought the star with the five holes went on the back
and that some of the covers had a place to drill the five holes under
the the stock circle
The directions were not clear at all.
Thanks again
