Polished lower sliders
Taped off and ready to start.
Twenty bucks worth of wet and dry sand paper form 400 to 2000 grit.
Total cost about fourty bucks including supplies,beer and chrome bolts/nuts and about fours hours total including breaks for lunch and beer.
Good Luck
Tom
can you go into a little more detail on how you did this?
Removed the front fender,taped off the chrome trim at the top and wrapped bearings and brake parts in tinfoil to keep grit out. The tape won/t stay on the chrome trim at the top for long, You'll just have to be careful not to scratch it.
Start out with a folded piece of 400 grit wet and dry sandpaper and a bucket of water and a hose. The bulk of your work will be here. Sand off the clear coat and keep sanding til the brushed finish is gone. Use plenty of water with your sandpaper and hose the sliders off every once in a while to check progress. This will take a long time to get the sliders smooth with no ridges but still very dull.400 grit will do the bulk of the work,600 and 800 to get the scratdhes left by the 400 grit. the rest of the finer grits will polish to a smooth finish.
Once you're satisfied with the first step just keep sanding with progressively finer grit sandpaper til the finish is very smooth. It will still be a little dull but very smooth. Then dry it off,check for blemishs and then use an old wash cloth to polish with semi-chrome paste. Rub till the cloth comes up black,clean and polish all the residue off with an old t shirt and do the semi-chrome one more time and polish again with the t shirt. Should shine like chrome. Reattach fender and stand back with beer in hand, admire the looks and remind yourself that you'r gettin too old to stay bent over for that long a time but maybe a few more beers will make your back quit hurting.
Good Luck
Tom
