Chaincase Drain plug on 2000 FXDX
Old Feb 7, 2010 | 11:09 PM
rounder's Avatar
rounder
Originally Posted by godjunior
On the primary chain cover there is the opening for where there used to be the shifter. The previous owner put some kind of chrome cap over the shaft I guess, never took off the chrome cover. Is the gasket or oring behind the chain cover going to be the same?? What prevents the oil from coming out of this shaft, is it an O-RING of some kind that is behind the cover.
Thanks
shaft is actually inside a tube that seals out the oil from the shaft. Shaft rotates to shift tube does not. Don't worry about it anyways. Only reason to go into inspection cover is if your plan on adjusting the primary chain.... good luck.
jra7050
Oct 20, 2017 07:02 PM
ffron69
Jun 18, 2015 06:23 AM
BigFatHawg
May 10, 2010 06:18 AM
rpmp3
Jan 20, 2008 10:12 PM
Modee1245
Sep 15, 2007 04:04 PM
