Fork Seal Kit??
Old Feb 8, 2010 | 02:15 PM
JRK5892's Avatar
JRK5892
man i just replace the fork seals and reuse the rest.... that is all
Old Feb 8, 2010 | 05:06 PM
kansaskid72's Avatar
kansaskid72
Account Retired
Wow, thanks CactusRed!
Anyone know of that aftermarket seal kit MidnitEvil mentioned? I don't care if it's Harley brand...aftermarket works just fine. If so I'll get the kit. If not, I'll order the fork seals only and if I run into problems I'll go down to the stealer and get only what needs fixin'...only have 2400 miles on the Bob, so they shouldn't be that bad. 2007 model so it's fairly new.
Old Feb 8, 2010 | 07:10 PM
amfhd's Avatar
amfhd
In case you don't already know,the Dyna fork springs have about 4 inches of preload on them. Be ready when you get down to the last couple of threads,because the fork cap wants to launch.If you do disassemble the forks,always replace the seals.Before you slip the new fork seal over the fork tube coat the inside of the seal with fork oil and take a piece of saran wrap and stretch it over the top of the fork tube,then carefully slip the seal over the saran wrap and down the tube. The saran wrap prevents the seal from getting nicked. For a seal driver try some 2"pvc. I slide the old seal between the new seal and the seal driver to prevent damage to the new seal. Stock HD fork oil is 10w, SE fork oil is 20w.
Old Feb 8, 2010 | 11:12 PM
MidnitEvil's Avatar
MidnitEvil
I don't know the brand of it, but I ordered it through Custom Chrome. I imagine J&P or anyone else like that would all carry the same thing or something similar.
REW13
13
Sep 1, 2017 05:18 PM
Traxxtar
Jun 6, 2015 04:43 PM
slyedog
Dec 30, 2013 09:25 PM
SURFOR Chop
Mar 15, 2011 08:20 AM
lowriderrob
Oct 21, 2009 02:31 PM
