baffle removal help
Old Feb 9, 2010 | 07:01 PM
davescreation's Avatar
davescreation
Default baffle removal help
i have a 08 street bob with vance and hines short shot staggered. what is entailed in removing the baffles and do i have to re map?
Old Feb 9, 2010 | 07:07 PM
noel serice's Avatar
noel serice
you have to pull the heat shield off and on the bottom of each pipe toward the end there ia screw for each pipe take those out then pull the baffles out. I did mine a while back but it sounded realy crappy to me so i put them back in.
Old Feb 9, 2010 | 07:14 PM
davescreation
well if it sounds crappy then i think ill scrap the idea. im just trying to get obnoxiously loud
Old Feb 9, 2010 | 07:20 PM
noel serice
i was cool sounding till you let of the throttle the the loud a$$ popping started. but is was loud! i guess i should have said it like this the first time.
Old Feb 9, 2010 | 07:43 PM
Shockcollar's Avatar
Shockcollar
you can drill out the baffles and it will sound pretty good
Old Feb 9, 2010 | 09:31 PM
blacknsilver's Avatar
blacknsilver
I used a dremmel with cutting blade to cut small square hole in back of heat shields where screws are to remove baffles and replace with BCT's. This way you do not have to remove the heat shields. Just another way to do it.
sincitychoppa
Mar 16, 2015 08:35 AM
yeahgofigure
Feb 10, 2014 11:20 PM
federij
May 6, 2009 08:24 PM
cornishman
Apr 8, 2008 08:32 AM
jr_c6
Exhaust System Topics
Dec 22, 2006 01:28 AM
