Install new headlight help???
Old Feb 17, 2010 | 07:52 AM
jcmusic's Avatar
jcmusic
You could pull enough wire into the light shell and then cut, retape and that way your connection will be inside the shell out of site!!!
Jay
bberck's Avatar
bberck
Guess it depends on the light, mine had to be spliced anyway so I pulled enough out of the neck that the splice could be pushed back in. I soldered them and used some heat shrink.
Old Feb 17, 2010 | 10:18 AM
Fastfwd's Avatar
Fastfwd
Are you talking about a new light with a matching connector? I can’t imagine not pulling the connector out of the frame and connecting it. I managed it and I’m not the world’s greatest mechanic.
There’s a thread on here somewhere that details how to do it. In my case it required unbolting the tank – I remember that much, but it wasn’t crazy hard to do.
My new harness was wired wrong and shoots the brights on dim and vice versa – you might check on your new light and switch the leads if you find that your light is known to do the same. I didn’t find out till I had mine hooked up.
Old Feb 17, 2010 | 10:30 AM
ghostrider69's Avatar
ghostrider69
I installed one of these on my bike. I used the stock harness from the bulb socket all the way to the plug. It was any easy swap and best of all, no cut wires.
http://kcint.zoovy.com/product/75-HL...Y-CUSTOMS.html
Old Feb 17, 2010 | 11:29 AM
hutchison101's Avatar
hutchison101
Default thanks for the help
this is the light I bought. If I used the harness how would I connect these wires to it?
Old Feb 17, 2010 | 12:03 PM
Baeseman1's Avatar
Baeseman1
Like someone else said - I pulled the wiring out of the stock bucket and fished it into the new light. No cutting/splicing and I could have the stock light back on in no time.
You new light - if it has the 3 prong connector on the back of the bulb, don't pay attention to the wires poking out the bottom. Run the stock wiring in it's place.
Old Feb 19, 2010 | 02:42 PM
hutchison101
Default tanks
I think I got it. AAAAA the beauty of a forum!
TheJoker78
Feb 11, 2013 12:39 AM
soup
Jan 7, 2012 04:50 PM
MyBeerBelly
Oct 18, 2009 12:42 AM
jam65
Apr 26, 2009 08:20 PM
CrewDawg
Electrical/Lighting/Alarm
Jan 31, 2009 07:29 PM
