Polyurethane Riser Bushings
Old Jul 27, 2006 | 06:41 PM
Zyklon's Avatar
Zyklon
Default RE: Polyurethane Riser Bushings
Veniculum!
I was kind of hoping that you would ring in on this thread. It was one of your posts that gave me the heads up on the poly bushings. Once again, “Thanks Man” they work great.
Zyklon
Old Jul 28, 2006 | 02:48 AM
veniculum's Avatar
veniculum
ORIGINAL: Zyklon
Veniculum!
Zyklon
See that...we help each other even when we don't know we're doing it. I'm glad my post guided you in the right direction!
As far as HD vs. aftermarket....I have the HDs. Considering the cost of most HD parts...these were relatively inexpensive. I'm sure either way you go, you'll have a noticeable improvement.
And to comment on the post that mentioned dampening...the stockers may very well dampen vibration a little more...but as a result, the bars really tend to move around a lot...especially if you have the mini-apes. I, personally, don't like the feeling. When the urathane bushings were installed, it felt a lot more solid...and like I said...the front suspension should provide all the damping you need. If it's not enough, I would suggest upgrading the suspension..not relying on the piece of junk stock riser bushings.
Good luck.
Todd
Old Jul 28, 2006 | 05:29 AM
hd_sob's Avatar
hd_sob
ORIGINAL: veniculum
ORIGINAL: Zyklon
Veniculum!
Zyklon
Todd
You guyz have convinced me as well. I will be getting the polys ASAP...
Old Jul 30, 2006 | 02:16 PM
hd_sob's Avatar
hd_sob
ORIGINAL: SDMF
I replaced mine with a set and they make a world of difference in the stability of the bars.
Possible stupid question, but here goes:
Can the bushings & chrome washers be installed, one side at a time, while the bars are MOUNTED, or do I need to take it all down to parade rest before removing/replacing them?
Anyone?
THANKS!
Turret_plug
May 2, 2017 12:25 PM
stal94gt
May 18, 2016 02:23 PM
maryvillept
Jan 24, 2013 04:41 PM
Figstr
Feb 7, 2012 09:42 AM
Azgunner
Dec 31, 2007 11:02 AM
