Riser Bushing Question
Old Feb 6, 2012 | 10:15 PM
Figstr's Avatar
Figstr
Default Riser Bushing Question
I'm going to be changing out my risers soon and bought poly bushings to replace the stock ones. However, I read another thread on apes and someone suggested solid bushings to the OP. Would this be something to seriously consider over poly and who carries them?
Old Feb 6, 2012 | 11:29 PM
Kowan's Avatar
Kowan
You can probably get them through Dennis Kirk, J&P Cycles, etc.
Solids will transfer all vibration through to you.
Stick with polyurethane bushings.
Old Feb 7, 2012 | 04:53 AM
Big Kev-O's Avatar
Big Kev-O
I have 12" apes, polys were a huge improvement over stock. Polys are very firm, they reduce the slop/play significantly and the vibration from the motor is about the same. Solid mounts shake your bars like crazy. You will be satisfied with your polys.
Old Feb 7, 2012 | 09:18 AM
JohnC FXDX's Avatar
JohnC FXDX
If you are not internally wired, I saw this thing called a bar snake. It goes inside the bars to help reduce vibration.
Old Feb 7, 2012 | 09:42 AM
Wide_Open's Avatar
Wide_Open
I have the polys and would recommend them as well.
jakedietz
Jul 19, 2023 04:38 PM
Turret_plug
May 2, 2017 12:25 PM
94-Sporty
Feb 24, 2013 09:35 AM
cf7go
Apr 20, 2012 07:28 AM
Inked624
May 6, 2009 05:19 AM
